Oil leak near distributor - Honda-Tech
Old 07-24-2010, 12:14 PM   #1
Default Oil leak near distributor
I've replaced the inner dissy o-ring and the out dissy O-ring and I still seem to have a leak under my car near passenger side even though those two seals are not leaking oil anymore.
I notice a few sensors screwed into the engine below the dissy, what are these and is it possible they are leaking?
Blazinmiller is offline   Reply With Quote
Old 07-24-2010, 01:31 PM   #2
Default Re: Oil leak near distributor
the sensors under the distributor are tapped into the coolant, and they would be leaking coolant. Maybe your valve cover or rear main seal?
sgraham01 is offline   Reply With Quote
Old 07-24-2010, 01:53 PM   #3
Thanks for the info.
I'm preying its not rear main but it's been a hot day here and I went out and got then engine really hot and I think it might be coming out of the new O-ring on the outer portion of the dissy.
I stuff a rag under there and I believe I see fresh oil. Maybe the website I ordered the 2 seals from set me the wrong one?
I the part # is 30110-PA1-732 which is a honda distributor o-ring.
Old 07-25-2010, 06:26 AM   #4
it's possible that the oroing got cut while installing the distributor. Get a new outer oring from HONDA. oil it lightly before installing it onto the dist. and then lightly coat the outside before installing the dist in the head.
Old 07-25-2010, 10:52 AM   #5
If I get a new o-ring and still have same issue do you see anything wrong with putting a ring of honda-bond type sealant around the nub at the bottom of distributor that goes into the head?
Old 07-25-2010, 02:27 PM   #6
you shouldn't have to do that, but I guess that or some silicone gasket maker would be fine. Just make sure that you soak up the oil in the end of the head that would touch the silicone while it cures. it would help to jack up the right side of the car so that the oil in the head will pool towards the other end. just make sure the bore is dry while you let the silicone cure (at least 4-6 hrs or so). I'd let it sit over night.
oil leak on back of block? blacktibby07 Honda Civic / Del Sol (1992 - 2000) 2 05-28-2011 04:58 AM
wtb a.s.a.p da dissy eg-6 life Southern California (Sales) 3 07-07-2008 08:12 PM
oil leak blackmfoggie Honda Accord (1990 - 2002) 1 08-23-2007 01:09 PM
Distributor Leak tca0bell Honda Civic / Del Sol (1992 - 2000) 2 10-18-2006 05:16 PM
vtec solenoid gasket? type Gendy Honda CRX / EF Civic (1988 - 1991) 7 04-02-2003 03:17 PM
Tags
1992, 1994, 2000, 2001, 2002, 94, accord, civic, distributor, honda, hondatech, leak, leaking, leaks, oil, prelude
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
