Oil for high mileage accord
Old 02-21-2008, 12:12 PM
Imaginethat238's Avatar
Default Oil for high mileage accord
Hey guys,
I have a honda accord with 145k+ miles. I'm using synthetic oil right now, but I like to change it religiously at ever 3k miles. Would it be a bad idea to switch to regular oil instead? I would only do this from a cost standpoint. Or, is the synthetic actually more beneficial for the life of the engine even if I am replacing it every 3k? Thanks.
Old 02-21-2008, 12:21 PM
2accrds's Avatar
Default Re: Oil for high mileage accord (Imaginethat238)
It would be fine to switch to regualr oil as long as you still change it every 3k. One of the main benefits of synthetic is that you can go with longer change intervals.
Old 02-21-2008, 12:27 PM
Perfectionist's Avatar
Default Re: Oil for high mileage accord (2accrds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2accrds &raquo;</TD></TR><TR><TD CLASS="quote">It would be fine to switch to regualr oil as long as you still change it every 3k. One of the main benefits of synthetic is that you can go with longer change intervals. </TD></TR></TABLE>
I used plain old dino oil changed out every 5k on my '90 Civic Si, and it had over 100k miles more on it than the OP's Accord has now when I sold it. Engine was all original, even compression, no internal work. On my current RSX-s, I'm using synthetic with 10k mile change intervals.
Old 02-21-2008, 01:55 PM
2accrds's Avatar
Default Re: Oil for high mileage accord (Perfectionist)
I'm sure 5k is fine if you drive in the highway most of the time and check the oil level once in a while. But, I'm **** and prefer a 3k change interval.
Old 02-21-2008, 04:38 PM
He knows where you live!
TheMuffinMan's Avatar
Lol
145k isn't "high"
Mine was at 200k when we swapped it.
The "High Mileage" oil causes the seals to swell up to prevent leaks, if you don't have any problems with the car, just continue using what you have now.
Also NO reason to switch to synthetic. Especially on a higher mileage motor.
Old 02-21-2008, 04:53 PM
JDM_Acccord's Avatar
Valvoline Max Life Oil
Old 02-27-2008, 01:58 PM
Klepto666's Avatar
Default Re: (JDM_Acccord)
yea 145k is not much mine is over 300 thousand miles i change oil every 5k to 6k
chrisff521
10-02-2013 03:47 PM
zeke1312
13
02-04-2010 02:59 PM
question
07-20-2005 11:59 PM
OdysseyHF
12-03-2003 03:24 AM
Quick Reply: Oil for high mileage accord
