odometer set back - Honda-Tech
odometer set back
Old 09-19-2002, 11:09 AM   #1
UseR's Avatar
Default odometer set back
Is it legal to set back the odometer when getting a new engine?
UseR is offline   Reply With Quote
Old 09-19-2002, 11:10 AM   #2
Life is Suffering
Brandon's Avatar
Default Re: odometer set back (UseR)
No.
Brandon is offline   Reply With Quote
Old 09-19-2002, 11:12 AM   #3
UseR's Avatar
Default Re: odometer set back (B the Turbo Pimp)
What if you wanted to sell the car, but he body had 100,000 on it but the new engine had les say 10,000?
Old 09-19-2002, 11:14 AM   #4
greensleeper's Avatar
then you produce the papers that says the motor has 10,000 miles on it and give it to the purchaser. plain and simple.
greensleeper is offline   Reply With Quote
Old 09-19-2002, 11:15 AM   #5
H-T Order of Merit
TouringAccord's Avatar
No, it's not legal. Although in certain state you can have it noted on your title that you have a newer motor in you car. If you have documented millage records on the newer motor you can even have the millage of both the chassis and the motor listed. Not sure what states allow it but I remember talking to someone that did it.
TouringAccord is offline   Reply With Quote
Old 09-19-2002, 12:12 PM   #6
TJCCARDCO's Avatar
No?
It is highly illegal, you cannot set back your odometer, because your just changing the engine, what if different things go on the car like brakes after 2,000 miles and the odometer says 12,000. Things like that should make you say, hmm..ya know I dont know what im talking about. Because, if you reset the odometer on any car, it is illegal everywhere.
There is no law that says "You can lower your odometer when you get a new engine." but there is one that says "Odometer Rollback is illegal". I think it's even punishable by jail time.
TJCCARDCO is offline   Reply With Quote
95 accord trip and odometer not working nukem384 Honda Accord (1990 - 2002) 25 12-05-2016 11:29 PM
how to roll back or forward odometer (for use when swaping gauges only) ej2kiid Honda Civic / Del Sol (1992 - 2000) 11 02-21-2011 07:42 PM
HELP turning JDM Odometer back JDM_WHR Honda Civic / Del Sol (1992 - 2000) 19 06-14-2009 12:06 PM
cluster. Crunks Honda Civic / Del Sol (1992 - 2000) 9 01-31-2007 03:38 PM
How to confirm miles on the clock on a car. YipMan_Style General Discussion and Debate 9 11-25-2002 09:42 AM
Tags
back, car, changing, easy, engine, honda, illegal, legal, new, nys, odometer, odometers, reason, reset, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
