Odometer Light & Clock Light Not Working
I have a slight problem. My odometer light and my clock light don’t work. I bought the bulbs from the local honda dealer (if I can still find them). My question to you is how hard are these bulbs to replace? Is there a thread that shows how to replace them? Thanks in advance.
2000 Accord SE 4-door
Re: Odometer Light & Clock Light Not Working (Riga89)
The clock pulls right out. The bulb unscrews 1/4 turn.
For the cluster, you need to remove the 2 screws on top of the trim, then pull the trim off (there are 2 clips holding it on the bottom; probably will be a bitch to get out). Then you have 2 screws on top and 2 on the bottom of the cluster; remove those. Pull the top out and unplug the wires. Then remove the cluster from the dash and change the bulb.
Re: Odometer Light & Clock Light Not Working (00 accord)
Ok, thanks for your help man. For the first time, I did something technical to my Accord and it was a success.
There is only one problem. While I was taking the clock out somehow I lost one of those plastic buttons that are in the bottom of the clock. There are three buttons you can press, hour, minute, and reset. I lost one of those buttons. Does anybody know where I can get one? Or even better, if anyone has one on here that I can buy or send to me for free please let me know.
The job was a success minus the loss of the button. This is a cosmetic issue and I LOVE my honda. PLEASE HELP!!!
Andrewzabomb
02-21-2012 12:32 PM
