ODBII Codes P0420 and P1457 What's Up ?
Old 03-15-2004, 07:37 PM
ougoboy's Avatar
Default ODBII Codes P0420 and P1457 What's Up ?
99 Accord 4 cylinder, PEP Boys pulled 2 codes
P0420 Catalyst System Efficiency Below Threshold
P1457 EVAP Emission Control System Leak Detected(Control Canister System)
What does this mean ??
Old 03-15-2004, 10:28 PM
KDKane's Avatar
Default Re: ODBII Codes P0420 and P1457 What's Up ? (ougoboy)
P0420 =bad catalytic converter- Honda warranty 8 yr/ 80K miles ? (I work 4 Acura, Honda boys will have to answer this)
p1457= most likely you left the gas cap loose when refueling, or problem in evap system good luck
Old 03-16-2004, 02:28 PM
ougoboy's Avatar
Default Re: ODBII Codes P0420 and P1457 What's Up ? (KDKane)
Hey KD thanks for the reply, I will check w/ Midas on the cat and see what
price they will quoat me, I will check the charcoal canister and its connections
and if they look ok I will replace the gas cap and see what happens
Old 03-16-2004, 02:33 PM
pimpinhonda's Avatar
don't waste your time with the gas cap. that would be a p1456. that is tank side. 1457 is EVAP side. you canister and shut valve are bad. take it to a honda dealer and see if it is covered. i know that they have an extended emisions warrenty on the check engine light. the P0420 is correct that you need a new cat
dnoonkeste
08-04-2018 07:42 AM
f22beaver
Honda CR-V & Element
07-22-2015 04:47 AM
mooneybeams
08-20-2008 06:36 PM
hockeyMike2489
09-27-2006 08:44 PM
accord98v
06-12-2006 03:57 AM
Quick Reply: ODBII Codes P0420 and P1457 What's Up ?
