obd1 to obd2 auto transmission help - Honda-Tech
Old 03-30-2010, 06:13 AM   #1
Default obd1 to obd2 auto transmission help
i need some help at this, I have a 95 honda accord ex f22a (i think its that its the vtec) with automatic transmission, the transmission was on its way out and my brother got a good deal on a f22a out of a 96 accord with the auto tranny. I didnt do any research on this because i thought it was the same engine and all figured it would be just changing it, when i took the engine out i was putting my old wiring harness on the new engine when i relized some of the sensors were differnt, thats when i looked up online and found out one is obd1 and one is obd2. I now got the wiring harness that belongs to the obd2 engine, if i used the obd2 engine, transmission, wiring harness and ecu and pretty much used everything from the car im taking the engine from would it work or would i still have wiring issues and need a adapter? i just dont want to buy a conversion harness if its not gonna help me. Everything i look up is going from obd2 to obd1 not the other way around thanks
graffini is offline   Reply With Quote
Old 03-30-2010, 02:18 PM   #2
Default Re: obd1 to obd2 auto transmission help
bump
Old 03-31-2010, 12:25 PM   #3
help anyone plz
Old 04-01-2010, 05:42 PM   #4
MM Gruppe B
MAD_MIKE's Avatar
Quote:
The VTEC engine is F22B1. The transmissions are all the same from 94-97.
If the engine was fine, then I would keep the original engine in the car. Just swap out the transmission. There are a few differences between the pre and post OBD2 engines. Easiest solution would be to pull the later engine and transmission back out, place newer good trans on original engine and be done with it. If anything, when you go to the parts counter you can just order for your year/model car without having to bother remembering what you changed.
K.I.S.S. is always a great mantra.
MAD_MIKE is offline   Reply With Quote
94 Accord H23A Vtec Swap Thread Scott Little Honda Accord (1990 - 2002) 105 02-21-2017 06:47 PM
A Tuning solution for automatic transmission vehicles is here | HA Motorsports HAMOTORSPORTS Performance 28 07-31-2015 06:38 AM
Need help with 98 accord h22 swap blackdelslo Honda Accord (1990 - 2002) 1 03-28-2008 09:06 PM
Desperate H22 swapper needs HELP!! 3litre190 Honda Accord (1990 - 2002) 1 07-25-2007 02:47 AM
How to convert an OBD2a 5th gens wiring to OBD2b bearboy80 Hybrid / Engine Swaps 0 07-09-2005 02:38 AM
Tags
2002, accord, adapter, auto, automatic, codes, harness, honda, motor, obd1, obd2, obd2a, odyssey, tranny, transmission, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
