OBD Port Location - Honda-Tech
OBD Port Location
Old 12-01-2011, 10:15 AM   #1
silentdub's Avatar
Default OBD Port Location
On a 96 Accord, should be OBD-II, where is the plug located?
I looked under the driver side dash and found nothing.
silentdub is offline   Reply With Quote
Old 12-01-2011, 10:28 AM   #2
Default Re: OBD Port Location
I'm not sure on CD5's, but on 90-93, the OBD1 port is just above the passenger side kick panel.
Have a look around there first, unless someone beats me with a verified answer.
crazymikey is offline   Reply With Quote
Old 12-01-2011, 11:36 AM   #3
HonBeer's Avatar
It is behind the *** tray.
HonBeer is offline   Reply With Quote
Old 12-01-2011, 12:05 PM   #4
That's an interesting spot.
Old 12-01-2011, 02:52 PM   #5
'96 is OBDII, right?
StreetsideStig is offline   Reply With Quote
Old 12-01-2011, 03:53 PM   #6
I think 95/96 and newer vehicles are OBDII.
I had a 95 Ford that was still OBD1.
Old 12-01-2011, 03:58 PM   #7
GhostAccord's Avatar
Yes the 96+ are OBD2. The 95 CD5 is OBD1.
GhostAccord is offline   Reply With Quote
Old 12-01-2011, 04:17 PM   #8
HonBeer's Avatar
BEHIND THE ASHTRAY...
Old 12-04-2011, 05:20 AM   #9
However the 96 4 cyl still had the two pin service connector on the pass side
Lost Again is offline   Reply With Quote
Old 12-04-2011, 07:58 AM   #10
That is correct. There are a few posts about the service check connector on here as well.
http://honda-tech.com/showthread.php...=service+check
Old 12-08-2011, 09:51 AM   #11
silentdub's Avatar
Thanks guys. I'm just trying to help someone out.
Honda ecu's - obd0, obd1, chipped dzminiz Northeast (Sales) 16 11-20-2010 05:37 AM
Obd2b to obd2a jumper AllMotorAri Northeast (Sales) 7 09-17-2009 04:59 PM
LS ECU's iblewmyrmotor For Sale 7 02-10-2008 05:12 AM
Need to buy ASAP OBD 1 to OBD 2 jumper harness WAT THA!!! For Sale 2 04-24-2004 06:09 AM
alternator connector, obd1 vs obd2 Urban Business Tech / Misc 2 10-05-2002 08:58 PM
Tags
1990, 2001, 2002, 2009, accord, diagnostic, honda, location, obd, obd1, obd2, obdii, odyssey, plug, port
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
