obd-II ecu wiring diagram needed
Old 03-05-2003, 09:54 AM
Cm91h22a's Avatar
Default obd-II ecu wiring diagram needed
need wiring diagram for obd-II ecu. please help
Old 03-05-2003, 12:33 PM
subnet's Avatar
Default Re: obd-II ecu wiring diagram needed (Cm91h22a)
[img]c:\image003.png[/img]
PIN 1 - Manufacturers discretion
PIN 2 - SAE J1850 Line (Bus +) *
PIN 3 - Manufacturers discretion
PIN 4 - Chassis Ground
PIN 5 - Signal Ground
PIN 6 - SAE J2284 (CAN High) *
PIN 7 - K Line of ISO 9141-2 & ISO/DIS 4230-4*
PIN 8 - Manufacturers discretion
PIN 9 - Manufacturers discretion
PIN 10 - SAE J1850 Line (Bus -) *
PIN 11 - Manufacturers discretion
PIN 12 - Manufacturers discretion
PIN 13 - Manufacturers discretion
PIN 14 - SAE J2284 (CAN Low) *
PIN 15 - L Line of ISO 9141-2 & ISO/DIS 4230-4*
PIN 16 - Unswitched Vehicle Battery Positive
* If a particular communication protocol is not used in a given application, the pins may be assigned other functions by the vehicle manufacturer.
Check out this site for more info http://www.obdiicsu.com/
mikester1222
05-24-2008 07:16 AM
emrekin
10-31-2007 12:53 PM
kungfuSiR
03-26-2002 03:07 PM
Quick Reply: obd-II ecu wiring diagram needed
