OBD 420, 1739
OBD 420, 1739
my check engine light was on, and after going to a auto shop and had them read the obd code for me. i found out it's turned on because it has problem with transmission(1739) and catalyst converter (420).
i have a honda accord le 1998 4 cyl with 82k mileage. any suggestion what should i do next. i already had mechanic to turn off the check engine light.
Re: OBD 420, 1739
I WAS TOLD IT WAS A 3RD CLUTCH SWITCH IN THE TRANSMISSION. IS YOUR CAR HAVING TROUBLE DOWN SHIFTING WHEN YOU COME TO A STOP SIGN AND DONT COME TO A COMPLETE STOP THEN TRY TO TAKE OFF?
MM Gruppe B
Re: OBD 420, 1739
If the primary O2 is old/lazy it may not be keeping the engine running at stoich. Also if the car is well overdue for a tuneup then this would also cause emissions issues.
pang07
01-07-2005 05:12 PM
92acclude
08-28-2004 09:52 PM
