O2 Sensor Stuck Lean
Old 06-03-2007, 07:27 PM
dakuda's Avatar
Default O2 Sensor Stuck Lean
My CEL came on today. Checking the codes, I get:
P2197 -- O2 Sensor Succk Lean, Bank 2 Sensor 1.
OK, where is bank 2, sensor 1?
2003 Accord, V6
Thanks
Old 06-03-2007, 08:40 PM
Global Moderator
tech8's Avatar
Default Re: O2 Sensor Stuck Lean (dakuda)
For your 03 Accord V6, I believe there is a Technical Service Bulletin (TSB) to reflash the ECM, which would be covered under the 8year/80,000 miles extended emission warranty. Has to do with tolerance range of the O2 sensors.
TSB #604 -- DIAGNOSTIC TROUBLE CODE P2195 OR P2197, LAF SIGNAL STUCK LEAN, V6 ONLY. *NM (NHTSA ID #10014139, JUNE 16 2004)
You may want to check with the dealer first. Even if you are over 80,000 miles, they may still possibly do it under goodwill.
BTW: Bank 1 is the side of cylinder 1, Bank 2 is the side of cylinder 2. Sensor 1 is the sensor closest to the engine.
Pooter05
04-18-2013 05:09 PM
frank jr
08-17-2010 08:46 PM
jlpicardq
06-11-2010 07:17 AM
Nizzy
05-22-2003 03:58 PM
Quick Reply: O2 Sensor Stuck Lean
