not over 3000 rpms!
not over 3000 rpms!
Yes my accord won't go over 3000 rpm's when i press the gas pedal or while driving it. it is like if it is cutting fuel or something but can figure this out. is it a sensor or something like it?
It's a 97 and it din't use to do that. only after we intalled the block of a prelude 93. and to do that we remove the tranny and engine because i replaced the tranny too.
no it's not an auto? but i found the problem the crankshaft sensor that is located close to the oil pump pulley was not receiving the right timing brcause the gear had a piece broken
Re: (acc97lxAndy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acc97lxAndy »</TD></TR><TR><TD CLASS="quote">It's a 97 and it din't use to do that. only after we intalled the block of a prelude 93. and to do that we remove the tranny and engine because i replaced the tranny too.</TD></TR></TABLE>
Didn't get the MAP and TP sensor conectors mixed up did you?
Re: (acc97lxAndy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acc97lxAndy »</TD></TR><TR><TD CLASS="quote">why do you think that i got the MAP and the TP sensors mixed up/</TD></TR></TABLE>
They don't run very well that way. Were they?
Atomic Ant
10-16-2017 11:01 PM
garfunkle55
06-14-2007 10:26 PM
