97 Accord. Odometer, Spedometer not working
Old 09-06-2017, 09:08 AM
willela12's Avatar
Default 97 Accord. Odometer, Spedometer not working
My v4 maunal 97 honda accord seemed to have a bad speed sensor as cruise control, my speedometer, and odometer were not working. I replaced the speed sensor and popped the fuses in and out to make sure everthing was fresh. Now, my cruise contol works but the odometer and speedometer still dont work. No check engine light Update: pulled fuse out again and now I've got the check engine light
Old 09-07-2017, 03:26 PM
Nlarge's Avatar
Default Re: 97 Accord. Odometer, Spedometer not working
And the code is........
Old 09-08-2017, 08:02 PM
johhnytsunammi's Avatar
Pretty common issue on these cars. I replaced my speed sensor a few times. It turned out to be the speedo itself. Just grab a cluster from the junkyard.
Old 09-08-2017, 08:07 PM
Nlarge's Avatar
or go digital!
Old 09-17-2017, 03:27 PM
willela12's Avatar
Where'd you get that digiatal cluster and $?
Old 09-17-2017, 03:42 PM
Nlarge's Avatar
i made it and wired it myself... any digital tach or speedo will work
Old 09-17-2017, 04:11 PM
angrysmileyface's Avatar
What brand of gauges fit like that? Is the wiring straight forward to the 4 connector points of each gauge?
Old 09-17-2017, 04:14 PM
Nlarge's Avatar
these ones are intellitronix... there is some minor fab required. Wiring is easy.. a few vampire tabs for power, ground and signal.
Viper05
06-20-2013 08:35 PM
Alwayscali
09-29-2012 04:29 AM
Perfectibilist
12-31-2010 07:03 PM
comptonfinest
07-19-2009 07:02 AM
Quick Reply: 97 Accord. Odometer, Spedometer not working
