NGK Spark Plug Wires ... F22B2 --> H22A
I have new spark plug wires for my F22 non vtec. I just blew the motor. I was wondering if I can use the wires from my F22 on my H22 since i just bought them. thanks guys.
edit: they are NGK R-8 wires.
Re: NGK Spark Plug Wires ... F22B2 --> H22A (Advan06)
from my experience nop they won't fit..seems like the f22 is shorter.
so you'll need to get some h22a's.
Re: NGK Spark Plug Wires ... F22B2 --> H22A (TakeiTeg)
Prelude - Custom performance wire set with ferrite magnetic core. Wire Length No.1 653mm 25.71in. Wire Length No.2 573mm 22.56in. Wire Length No.3 433mm 17.05in. Wire Length No.4 353mm 13.9in. Coil Wire Length = 364mm 14.33in.
Accord - Custom performance wire set with ferrite magnetic core. Wire Length No.1 709mm 27.91in. Wire Length No.2 589mm 23.19in. Wire Length No.3 569mm 22.4in. Wire Length No.4 429mm 16.89in. Coil Wire Length = 384mm 15.12in.
Accord ones are longer... is there anything that has to do with the m4d VtAK that wont make it work?
