92 accord rear toe adjustment??? 3 degrees???
Hi, my 92 accord was hit by a street cleaner, and since they won't admit it and fix it, it's on me...It was parked and hit from the drivers side into the curb. The DS rear tire is toed in 3 degrees. I've replaced everything to stock except the knuckle with no change. I have seen aftermarket rear lower control arms that adjust, but only 2 degrees I think...Camber on the Drivers Side left rear is still perfect, but the camber on the right rear is out. I have purchased aftermarket upper arms to adjust camber, but I'm waiting to see if i can even get the DS rear tire close to straight! Is there an adjustment on the small lower control arm stock? I can't find one. Help! Thanks!
Re: 92 accord rear toe adjustment??? 3 degrees???
Yeah, the front LCA has an eccentric inner bolt for adjusting toe. Make sure the mounting hole in the subframe hasn't stretched as well.
