Newbie with a Accord problem...
Old 01-29-2005, 03:40 PM
pwhited's Avatar
Default Newbie with a Accord problem...
93 Accord EX, 2.2, all stock. The car stalled a couple times last night, but would restart and go with no trouble. After I got home last night I went out and started it, it ran for about 45 seconds and then stalled. Started it again, same thing. This morning it started, and when I put it in reverse it stalled and would not restart. Decided to look at the dist. cap, and found greenish corrosion in the coil wire tower on the cap. Nowhere else though, just where the coil wire plugs into the cap and that end of the coil wire. Rest of the cap looked good, minor tracing on the inside, rotor looks fine, plug wires good. (fairly new in fact) Plugs look great, nice burn. Got it inside the garage (by pushing it) and it would start and immediately stop running. Replaced the dist. cap, same thing. Crappy Haynes manual says possible coil, so replaced the coil. Same thing, starts and dies right away. Now I'm stuck. Any help with this would be greatly appreciated, I don't know much about Honda cars.
Thanks..
Old 01-29-2005, 04:52 PM
judonoh's Avatar
check for fuel, make sure engine is getting fuel.
Old 01-29-2005, 06:26 PM
pwhited's Avatar
Default Re: (judonoh)
Nope, it's getting fuel. If I pull the coil wire from the dist. it will spark for a second or two when cranking, then stop. It's definitely spark related.
Old 01-31-2005, 09:59 AM
jamesyoung28's Avatar
Default Re: (pwhited)
i had some issues on my 93 ex coupe like that i went ahead and replaced the whole distibutor assembly and put on new plugs and wires.. it went away after that.. i dunno.. could be the ignition switch or some relay or something
Old 01-31-2005, 02:42 PM
pwhited's Avatar
Default Re: (jamesyoung28)
I looked all over for the main relay, thought I had it but it turned out to be the turn signal relay, hehe.. I know this much, ya gotta have really small hands to dig around up under that dash, it's a nightmare. I unplugged things and listened for the fuel pump, I don't think I ever located the main relay. Funny thing is, it started the next day and ran real good, better than ever, but it wouldn't start the day before after replacing coil and distributor cap & coil wire. I did have the battery charger on it for several hours though, since we ran it down cranking it. So either the new parts/battery charge took care of it, or I jostled something under the dash and made it work. I guess I'll find out one way or the other over time.
Give me the two wheeled Hondas anyday, those I can work on. Except they almost never need it..
Thanks!
RobbyD
10-17-2018 06:10 AM
Johnal130
04-12-2014 02:47 PM
ianae86
12
04-12-2006 06:05 PM
thug252
14
10-24-2004 04:58 PM
t25hatch
10-20-2004 11:10 AM
Quick Reply: Newbie with a Accord problem...
