F22 and H22 Compatibility
Old 07-02-2006, 08:28 PM
Laupro's Avatar
Default F22 and H22 Compatibility
Hey, i'm new to Honda-Tech. I was wondering if anyone knows if the header from a 4th gen Accord F22A1 would mount to an H22 engine? Because i will be doing a swap to a JDM H22. I would also like any tips possible to help during the swap!
Thanks
Old 07-02-2006, 08:54 PM
ftspyder's Avatar
hey im actually doing the same swap so im on the same boat as u
Old 07-03-2006, 05:06 AM
ilikehonda's Avatar
Default Re: (ftspyder)
no it will not
Tips:
1. make sure to get the prelude high pressure side of the powersteering pump. you will be using the prelude pump
2. your f22 mounts will work just fine. you will only need to trim a little bit off of the driverside mount to make it fit
3. be sure and get the correct ecu. (p13)
4. go ahead and convert the dist to an internal coil. it will make things easier. It will work external coil, but it also makes the engine bay cleaner.
5. have fun
Old 07-03-2006, 05:15 AM
In a Junkyard near you.
Ross 2.0's Avatar
Welcome to H-T. This topic has been covered many times before. For the future just use the search feature. you can get your information a lot faster
Old 07-03-2006, 05:18 AM
H-T Order of Merit
George Knighton's Avatar
Default Re: (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">no it will not
Tips:
5. have fun</TD></TR></TABLE>
o2 jockey
10-30-2007 02:40 AM
.BigSexy
06-03-2006 08:06 PM
PBrown
02-19-2006 02:19 PM
WARCOVENANT
12-24-2005 06:48 PM
kerris92lude
05-06-2005 03:37 PM
Quick Reply: F22 and H22 Compatibility
