Need torque specs! 1997 Accord!
Old 09-06-2007, 12:05 PM
drcain's Avatar
Default Need torque specs! 1997 Accord!
Can anyone help me get the Torque Specs for a 1997 Honda Accord? I need them for the upper and lower ball joints as well as the tie rod ends.
Thank you!
Old 09-09-2007, 10:34 AM
offcamber's Avatar
Default Re: Need torque specs! 1997 Accord! (drcain)
sorry, don't know, but go to helminc.com and buy a repair manual if you plan to continue to mod/repair your car, or for now try going to your local auto parts store to see if they have it. you can also see if your local library has the "alldata" database.
Old 09-10-2007, 03:41 PM
The-Kid's Avatar
Default Re: Need torque specs! 1997 Accord! (offcamber)
This is from the Haynes Manual for a 94-97 Accord...
*ALL IN FT lbs
(front)
Upper control arm ball joint nut=32
Upper control arm pivot bolt/nut=22
Steering knuckle lower ball joint but=40
Lower control arm inner pivot bolt=40
Tie-rod end to steering knuckle nut=32
cmb7684
11-23-2014 06:29 AM
mossimo817
10-18-2004 12:24 PM
lysol
04-27-2004 10:41 AM
Quick Reply: Need torque specs! 1997 Accord!
