Again with the axels?????
Old 08-15-2007, 06:01 PM
CD5 Jeebies!'s Avatar
Location: Free bullets if you find me sucka, Washington
Default Again with the axels?????
A little while ago I posted a thread https://honda-tech.com/zerothread?id=2064495
Now I am having the same exact problem??!?!?! the axel is fine we stretched the clip as far as it will go and since it has pooped out 4 more times.....I really at a lost on what to do..the car ran great untill this crap started happening so I dunno!!!! any help input appriciated.......
Old 08-15-2007, 06:42 PM
JimBlake's Avatar
Default Re: Again with the axels????? (I got the CD5 Jeebies!)
Have you done anything to the suspension geometry lately? Something to position the steering knuckle further outboard? Just checking everything, although it seems like that would pull the tripod out from the inner driver instead of what you're getting.
New axles lately? ANYTHING different anywhere?
Old 08-15-2007, 06:44 PM
Default Re: Again with the axels????? (JimBlake)
nope...just the new axel 7000sih miles ago..although I did for a while have some loose bolts on the lower crossmember that were loose and causing noise and vibration???? noises like a broken motor mount. But I tightened it and it went away???
Old 08-17-2007, 11:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">checked fluid fine, checked axels fine, checked shift linkage fine.......started working on it today and I noticed something (i can shift through all 5 gears w/out clutch) when I engage a gear the SPEDO jumps to 20mph(the car aint moving) 1st-4th but when I engage 5th it jumps to 35mph!?!?!?!? Also when I hit the accelerator the SPEDO jumps accordingly to the tach...for example if I rev the motor to 4500 rpms the SPEDO say 45mph!?!?!? 6000 rpms 60mphs! I did this numorously so it seemed consistant...also I hear a quiet whiney klicky sound coming from the tranny while its engaged? i dunno I stumped any outside input would be appriciated</TD></TR></TABLE>
HELP!!!!!!!!!!!!!!! THis is driving me nuts
Old 08-20-2007, 08:03 AM
JimBlake's Avatar
What about damage to the internal splines during the time when the axles were popped out? When you engage a gear & try to drive, the differential spins but the axle doesn't. Seems like you're grinding away at those splines whenever you do that.
I don't know how fast that would grind away, or what's the best way to check that... So this is just an idea - maybe someone can say what their experience has been for something like that.
Old 09-10-2007, 03:18 PM
Oh I just figured that since the problem got fixed I should post my results......The axel was a Defective rebuild.......new axel problem fixed..
sarends
12-22-2013 04:27 PM
i_VTEC
10-03-2007 05:07 PM
thenick
16
02-27-2007 10:56 AM
98lude-t
10
05-07-2006 04:44 PM
Quick Reply: Again with the axels?????
