need rocker arm assembly torque specs (searched)
https://honda-tech.com/zerothread?id=933519
^ that's all i found
i've looked over and over in the haynes manual (yea i know that's the reason why) . but yet i still can't find the specs for the rocker arm assembly bolts.
any links or knowledge dropped will be appreciated.
94 LX f22b sohc non vtec. thanks in advance
H-T Order of Merit
Re: need rocker arm assembly torque specs (oem_certified_accord)
uh, isn't there a specific sequence those are supposed to be torque in? I don't have my manual in front of me otherwise I would look it up. Just making sure, wouldn't want something to go wrong thats all.
Re: need rocker arm assembly torque specs (TouringAccord)
there is, it's a cross hatch type of pattern in a sequence of 1-18. i have that memorized i just shot my brain nerves trying to find torque specs. had to switch heads over an over-torqued 10mm rocker assy. bolt.
thanks though peoples
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">uh, isn't there a specific sequence those are supposed to be torque in? I don't have my manual in front of me otherwise I would look it up. Just making sure, wouldn't want something to go wrong thats all.</TD></TR></TABLE>
getting to be a picky old fart ain't ya? LMAO Guess thats why you are 101%
Here's a link.
http://img212.imageshack.us/my...1.gif
Here's a link.
Re: need rocker arm assembly torque specs (hondadude)
thats not the tightening sequence for the f22b2 engine
edit: i think the rocker arm battle is over since i did a headswap. will find out tomorrow because after i put it all back together i found out the batt was dead so no crank dat today.
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">getting to be a picky old fart ain't ya? LMAO Guess thats why you are 101%</TD></TR></TABLE>
LOL
LOL
Re: need rocker arm assembly torque specs (searched)
I have a 95 prelude with f22b motor and im changing the lower spark plug seals and just checking the torque spec on the 10mm heads and the 12 mm heads on rocker arm assembly and is there a sequenceto tighten the bolts in
