Need Help...Locating Transmission Drain Plug!?!? - Honda-Tech
Old 08-04-2006, 02:24 PM   #1
Tech-Nics's Avatar
Default Need Help...Locating Transmission Drain Plug!?!?
can some one please post a picture of where the transmission drain plug is?
or atleast explain where its located...im going to do a drain and refill...
thank you...
Tech-Nics is offline   Reply With Quote
Old 08-04-2006, 02:55 PM   #2
businessmanph's Avatar
Default Re: Need Help...Locating Transmission Drain Plug!?!? (Tech-Nics)
it's near the front passenger tire
get a 3/8th ratchet
and stick it into the square shaped bolt
businessmanph is offline   Reply With Quote
Old 08-04-2006, 05:54 PM   #3
sony224422's Avatar
Default Re: Need Help...Locating Transmission Drain Plug!?!? (businessmanph)
its in there pretty tight too.. make sure you use a big rachet
sony224422 is offline   Reply With Quote
Old 08-04-2006, 08:27 PM   #4
JimBlake's Avatar
Auto or manual tranny? V-6 or 4-cyl? It matters.
JimBlake is offline   Reply With Quote
Old 08-04-2006, 09:24 PM   #5
Tech-Nics's Avatar
auto/4-cyl
Old 08-04-2006, 11:16 PM   #6
MestizoRacer310's Avatar
Default Re: (Tech-Nics)
Passenger side like businessmanph said. Make sure to use a long handled ratchet...
MestizoRacer310 is offline   Reply With Quote
Old 08-05-2006, 02:24 AM   #7
iam7head's Avatar
Default Re: (MestizoRacer310)
Quote:
bad idea actually, most people use a long rachet and turn it slowly, because the metal to metal contact it's easy to stripe the bolt that way.
use a regular size handle and give it a quick blow, one good yank will break it loose
iam7head is offline   Reply With Quote
Old 08-05-2006, 08:05 PM   #8
Default Re: (iam7head)
What metal to metal contact are you talking about? Not trying to sound dumb or nothing but I don't see what you're speaking of...
Old 08-06-2006, 07:38 AM   #9
Tech-Nics's Avatar
well...the drain and refill was a complete success...thanks to you guys for helping me out...the lug came out with one great big jolt...i used the regular size ratchet. came out like a champ. looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
thanks again to all that helped me...
Old 08-06-2006, 07:30 PM   #10
thatasiankidtony's Avatar
I used another ATF brand, do you guys think that can be a reason it's shifting hard?
thatasiankidtony is offline   Reply With Quote
Old 08-06-2006, 07:33 PM   #11
JimBlake's Avatar
Quote:
Originally Posted by Tech-Nics
... looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
Fill whatever amount makes the correct level on the dipstick. (Car warmed up, shift into park, turn OFF the engine.) Don't simply go by quarts. The tranny & torque converter have something like 7 or 8 quarts in there, but only 1/3 or 1/2 of it can drain out.
Draining and refilling Transmission fluid question dth0ng69 Honda Civic / Del Sol (1992 - 2000) 10 07-20-2012 07:07 AM
changing manaul transmission fluid whiteboy03si Honda Civic / Del Sol (1992 - 2000) 1 03-08-2007 02:45 PM
transmission flush H22A4Me Honda Prelude 2 01-19-2006 09:58 PM
WHERE IS THE TRANSMISSION FLUID PLUG? RACERX72 Honda Prelude 19 05-12-2004 02:15 PM
Transmission oil drain/filler plug washer question gsrclan Acura Integra 2 04-17-2003 01:54 PM
Tags
2006, 90, 93, accord, drain, f22b, honda, location, lx, picture, plug, prelude, sh, tranmission, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
