Need help identifying connectors (pix inside) 1991 accord
I posted on cb7tuner but didnt get much response at all...
hey guys as some of u know im doing my wire tuck, well my lazy *** finally made some progress and now im ready to re-run the wires, however i forgot where some of these connectors connect to lol so if you can help me out that be great basically i need to know which connectors are running outside of the fenders to the front of the car, which are stayin in the bay, which are goin inside the car (fusebox is goin inside the car, i know which connectors run to it).
Thanks for any help! Also the first imagine i need help with!
Modified by aleks77 at 9:57 PM 12/10/2007
1 Post
Re: Need help identifying connectors (pix inside) 1991 accord (aleks77)
I know #4 and #8 are ground connectors (hence the black wires). You need to bolt that ring on there to a good ground spot on the frame.
The rest I don't know for sure, but usually they will only fit one other connector, you just have to do trial and error to match them up. If you do have 2 coonectors that are the same, then just match up the wire colors going into the connectors and you're set.
the engine is out of the bay, i cant really plug it into anything....and i have to know if i have to run them to the front or leave them in the back of the engine bay before the engine goes in...
