Need Help On HVAC Mode Control
I have noticed recently that no matter what mode I select, air comes out of the side front (so drivers and passenger sides) vents. This is an issue only because when the defrost is on, barely any air comes out the defrost vents on the sides, only from the front vents. The central vents switch just fine. My solution thus far has been to close the side vents. All i really need is a diagram or something of the sort of the HVAC doors / vents. I looked under and all the door mechanisms are intact, nothing is broken or hanging off. However, without a way of knowing what I am looking for, I really can't do much.
Also I'm not certain if this is supposed to happen, or not. The reason I'm guessing not is because when its on feet only, it still comes out full force from the side vents. And just to be clear, all the other vents are switching on and off just fine.
Re: Need Help On HVAC Mode Control
Welp I found a FSM online literally just after posting this...
Strange considering i spent a good 2-4 hours searching before.
UPDATE the FSM shows the air always coming out the side vents, im guessing my defroster door is not opening fully? Only thing i can think of...
lmike6453
09-02-2008 06:27 AM
crxtreme89h
12-12-2005 03:17 PM
TC21
06-15-2005 09:20 AM
