Need help with 98 accord h22 swap
What I have is an auto 98 accord that was converted to 5spd. Im using the stock auto engine harness on the h22 which is obd2a and also wanting to run the conversion harness to go from obd2b - obd1.
My question is that the stock accord has 4 ecu plugs A B C and D. What I need to know is that the D plug is all auto stuff right? Because when i use the conversion harness there is no wires that go to it.
I looked at a wiring diagram on phearable for obd2b cars and some of the wires are not the same color that the website says they should be in the same spots.
Is this swap the same deal as the civic/integras or does the 6th gen accords have something slightly differant?
I should just be able to use the stock engine harness, mate it to a conversion harness and then just add any wires i need for the h22 right? No switching pins to differant plugs and stuff right?
Here's one of the best h22 resources on the web for the 6th gen.
http://www.everything-honda.co...=3843
