need help! 1993 accord dies while driving - Honda-Tech
Old 12-18-2011, 07:44 PM   #1
Default need help! 1993 accord dies while driving
My girls 93 accord suddenly dies while its driving and just coasts with all the electrical stuff on. Then it will just crank over but not start. She said to get it to start she disengaged the shift lock and put it in neutral, took the key out of that then it started right up. In the past when it was rainy it wouldn't start it would just crank over but it has been a few months since it did that. I haven't noticed and cracks in the distributor or Ive heard it may be a problem with the ignition module. Please if anyone may know anything about this.
boostedh22fag is offline   Reply With Quote
Old 12-19-2011, 07:36 AM   #2
GhostAccord's Avatar
Default Re: need help! 1993 accord dies while driving
Could be the main relay needs to be soldered/replaced. There is a lot of information online related to diagnosing and fixing the infamous Honda main relay issue.
I have never personally had to deal with the main relay issue. However, I did have an issue with my ignition control module. It wouldn't start at all after it quit. No spark. Seems as though your issue is more of an intermittent problem, main relay or maybe a coil issue.
GhostAccord is offline   Reply With Quote
Old 12-19-2011, 01:17 PM   #3
As usual, I agree with Ghost. Main Relays go out all the time, and really start to act up in when the weather changes, because that's when the soldering comes loose. The part is about 50 bucks at a parts store, or you can resolder it yourself.
Pull it out and take the cover off. If you have carbon scoring around the solder points, it needs work.
StreetsideStig is offline   Reply With Quote
Old 12-19-2011, 02:00 PM   #4
Bruce Banner's Avatar
Could it be his dizzy?
Bruce Banner is offline   Reply With Quote
Old 01-16-2013, 02:33 PM   #5
My 93 Honda accord died on me while driving and will not restart. I changed the plugs and wires but the plugs are not getting fire, please help
Rainydrought is offline   Reply With Quote
Old 01-16-2013, 06:28 PM   #6
Crxh22ajdm's Avatar
^^ maybe a bad coil, or something in the distributotr.
Crxh22ajdm is offline   Reply With Quote
Old 01-16-2013, 06:36 PM   #7
Crxh22ajdm's Avatar
Quote:
That happen to me and guess what, it was my timing, I dont know how but the tensioner was losed, I had a missing bolt in there, and only somethimes the car star, then while driving it the car will died, I part out the engine and tranny and got ab H22A with only 59xxx on it
Old 01-16-2013, 07:28 PM   #8
SlowDA9teg's Avatar
Quote:
Same problem I'm having. I decide to have my battery,and alternator checked at the parts store and bought a new ignition control module and got a backup main relay at the junkyard. All I have to do now is hookup everything up and hopefully it starts .ill let you know how it goes so I can hopefully give you an idea of what it was in case you don't find it before me
SlowDA9teg is offline   Reply With Quote
Old 01-16-2013, 08:20 PM   #9
More than likely the ignitor (Ignition Control Module) inside the distributor.
Old 01-18-2013, 01:30 AM   #10
before jumping the gun try cleaning your battery terminals, grounds, etc
ozmannnnn is offline   Reply With Quote
car wont start MurtazaDSM Acura Integra 21 05-28-2012 01:11 AM
my accord stalled/died while driving - PLEASE HELP - euroborn1 Honda Accord (1990 - 2002) 13 04-22-2010 06:50 PM
h23 prelude NEEDS HELP jdmeg9 Honda Prelude 6 04-20-2010 02:42 PM
engine dies after warm up won't start again jedbo Honda CRX / EF Civic (1988 - 1991) 2 06-13-2009 04:39 PM
My 90 Honda Accord LX died while driving DeadLikeMe Honda Accord (1990 - 2002) 1 08-22-2007 05:57 PM
Tags
1993, 93, accord, completely, die, died, dies, driving, engine, honda, locked, main, relay, road, tje
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
