need f22b1 vtec wiring help 96 accord - Honda-Tech
Old 03-14-2011, 04:20 PM   #1
Default need f22b1 vtec wiring help 96 accord
I know there is info everywhere, but I cant seeme to find all the info I'm looking for. I am finding all h22 but thats not what i need.
I bought a 96 accord LX Auto(non vtec) with an f22b1 vtec motor. The vtec is NOT wired or working. (The car might be in limp mode, not sure. This is my first honda.)
Anyway, I bought the P0H ECU. I had to replace all the wiring under the dash because it was burnt and melted. I did NOT get the engine wiring harness.
When I get up to vtec kick in point it doesnt shift, I have to let off for it to shift.
I have read that I need to wire the vtec solenoid and oil pressure switch. My motor does NOT have the oil pressure switch, there is a bolt in it. I checked the junkyard and they are the same. I am not able to buy the switch at the parts store.
Does the oil pressure switch have to be wired? Where can I buy one? Does anyone have the ecu pinout with wire colors for the 96/97 obd2? Help me please. I'm getting a vtec malfunction code with the CEL and I need to get the car inspected this week and the CEL can't be on. thanks
karen7 is offline   Reply With Quote
Old 03-21-2011, 06:32 PM   #2
Default Re: need f22b1 vtec wiring help 96 accord
bump. Still needing this info. Thanks
Old 04-23-2011, 07:56 PM   #3
i am having the exact problem and am nearly there with the answers but still dont have the pin up yet. i was told to google 2.2 v-tec obd2 pinout and there you should find what you looking for im still stuck if you have any luck please help me thanks
eugenrosado is offline   Reply With Quote
Old 04-24-2011, 06:33 AM   #4
Search...I've seen this discussed here several times....heck it might actually be in the FAQ.
http://www.honda-tech.com/showthread.php?t=2706310
poorman212 is offline   Reply With Quote
Old 04-24-2011, 02:51 PM   #5
GhostAccord's Avatar
lol nice link^^^
The OBD2 F22B1 VTEC does not have a pressure switch. It only has the VTEC solenoid, that is why there is a bolt where the PSW usually is. The VTEC solenoid is wired to Pin A8 of the VTEC ECU. The other wire of the solenoid goes to chassis ground.
OBD2 Connectors, view from wire side
Wire colours around the VTEC pin;
A1 is YEL
A2 is BLU
A3 is RED
A4 is BRN
A5 is ORG/BLU or ORG/BLK
A6 is ORG/BLK
A7 is empty
A8 is GRN/YEL VTEC Solenoid............
A9 is BRN/BLK
However if you are adding VTEC to a non VTEC Accord. I don't think the GRN/YEL VTEC wire will be in the ECU wire harness.... Unless you replaced it.
GhostAccord is offline   Reply With Quote
Old 06-07-2011, 12:57 AM   #6
hey i have all ready did this swap, i was able to buy my motor with harnes it all bolted striat up with my f22b2 auto trans, the harnes pluged up just fine and i had found the right ecu i just had to run a wire from the ecu to my harnes for the vetec and im proud to say iv had it up to 130mph
thomas's96vetec is offline   Reply With Quote
Old 02-26-2013, 05:11 PM   #7
Quote:
Originally Posted by GhostAccord View Post
lol nice link^^^
A1 is YEL
A2 is BLU
A3 is RED
A4 is BRN
A6 is ORG/BLK
A7 is empty
A9 is BRN/BLK
hi i have a 97 accord ex and there is a male connector on the oil pressure senesor (i think that is what it is called) that screws onto the the vtec solenoid but i can not find the wiring to plug into it. the plug that is missing is green. my car is putting out p1253 engine code. wanted to know if anyone knows where the wires start from so i can run new wires and if that is the reason for the engine code.
brandon9686 is offline   Reply With Quote
The Official "Why VTEC doesn't Engage" Thread prelittlelude Honda Prelude 145 10-23-2016 12:59 AM
need help with vtec darkbombers Honda Prelude 3 01-21-2012 02:42 PM
Help! my B20VTEC has no VTEC! 95k24hatch Honda CRX / EF Civic (1988 - 1991) 23 05-29-2011 11:23 AM
Oil pressure gauge h22lude317 Honda Prelude 4 03-23-2009 12:54 PM
Cel code 22 H22a nelsond Honda Accord (1990 - 2002) 0 03-22-2007 09:06 AM
Tags
1993, 1996, 91, 92, 96, accord, ecu, f22b1, h22a, honda, locate, pinout, vtec, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
