Necessary to paint primered parts?
Aside from looking ghetto as hell, is there any reason that I HAVE to paint a factory primered hood for example? Will it hold up through the winter and what not?
Thanks.
Thanks.
Re: Necessary to paint primered parts?
Recently I noticed my left rear door was starting to show a bit of rust on the lower part. This door had been replaced and repainted some three years ago.
The folks at the paint shop explained me that three years ago the repair job had not been done properly: they had sprayed the correct color paint but had not used enough layers of transparant coating to protect the painted surface.
Just paint it! If it does rust it will be a pain to remove rust, then prime, then paint. Just paint it with anything close to the color. Most primer does rust because its has a rough finish to let the paint stick to it. So water likes to stick too.
So, the black finish, is better than primer... but... it will rust too, because rain isn't just water anymore, it has acid to it, and that will eat away the finish. The black finish will become less and less shinny once exposed to the environment and rain, until rust starts to build up on the surface, it's a matter of a few months until it happens.
I recommend you to paint the hood as soon as you can, doesn't even have to an expensive paint, but get it done... that will save you from having to sand rust or even having to buy a new hood.
here's the hood in question. You can see from pics (hopefully) that the primer that came on it is kind of shiny. the first pic shows this the best.. idk, it seems different from other flat primers i've seen. i guess it still probably needs painting?
It does need to be painted, i remember i got a new hood once and just rocked it like that and a couple weeks later it was all faded.
R-Toyz.com
Paint and Body
14
07-05-2007 08:34 PM
