Mysterious Oil Leak + Oil always on
Ok, i looked through some of the other threads to see if anyone posted a matching problem but didn't find any so let me start out with...
1993 Accord EX
replaced the oil pressure sending unit around 4 months ago. no leaks prior to the replacement but the oil light would fade in and out then sometimes stay after driving longer than 20-30 minutes. did the oil change & filter, of course while replacing sending unit. no problems afterwards (other than a very slow leak that i thought maybe coming from the pan) until a week ago. checked the oil and it was about a quart low so i filled it.
a few nights ago, i started the car up and the oil light was on and stays on all the time. the next day i noticed a rather massive leak. oil seems to be dripping out somewhere between the oil filter and pressure switch and dripping on to the part of the exhaust that crosses underneath the oil pan causing lots of smoke.
yesterday, after cleaning the engine up really good and getting underneath it, i still could not determine exactly where it was coming from. my roommate, who knows alot more about fixing cars than me, who also helped install the pressure sending unit was stumped as well. he seems to think that either the sending unit failed or that it could be leaking somewhere above the oil filter.
does anyone here know what might be causing this? between sunday and labor day, i can't take it to a garage to get looked at. i hope it isn't something too serious.
1993 Accord EX
Re: Mysterious Oil Leak + Oil always on
oops...thread title should read "Mysterious Oil Leak + Oil LIGHT always on"
the thing is, it doesn't seem to be coming from the filter, but its hard to tell.
there is nothing leaking from anywhere near the PCV valve, i pulled it off and it didn't appear to be clogged. plus its not very old.
Well I finally got around to fixing this and it was in fact the oil pressure sending unit. Don't buy Duralast, they're junk parts.
I just now saw the thread, but for future reference, you almost always want to go with the OEM sensors. Almost any other brand, for any sensor, will give you grief.
Yeah the durolast that i got from autozone was a piece of junk but the bwd unit from advance looks like its much better quality. it was only $7 so if it does go bad i will definitely replace it with oem part from the honda dealership. i'm just relieved that this minor fix was the cause of the oil leak *knock wood* and not something major...or majorly expensive.
I just figured I'd post an update just in case someone else runs into the same problem and is looking for a quick answer. STAY AWAY FROM DURALAST. and hopefully i won't have to come back to this thread in a few months to say "stay away from BWD" haha.
i bought that sending unit from advance, but didnt need it. the plug to it was just loose ha, is it a good one. ill prally put it in my next engine?
yeah. my cousin bought a fuel pump that breaks 100% of the time when you install it. they bought like 7 times before they gave up. some parts are a joke. look em up before you buy.
