Mysterious Hole in Oil Pan....
#102
Premium Member
Re: Mysterious Hole in Oil Pan....
F22 trans won't be ideal but it'll work just fine. You can look into getting a shorter geared trans down the road if that bothers you.
Phearable is fine. You can also get a base calibration from them that will allow you to drive the car to a tuner. Xenocron is another alternative. You only need the conversion harness if your car is model year 96+.
#103
#104
Premium Member
You convert the engine to work with the car. Not the other way around. Your car is a 1993, correct? So you will need an OBD1 H22 distributor and to reuse your factory harness & OBD1 F22 alternator.... You don't need a conversion harness. The chipped ECU will directly replace your factory one. If you don't know the specifics of what your setup will be once completed, just wait and order the ECU when you near the end of the swap.
#105
#106
Premium Member
Yes. But there will be 2 different models. External coil and internal coil. For simplicity you need to get the one that matches your factory internal or external coil setup so it will plug right in without having to do more wiring.
#107
Well if Im not mistaken the H23A has an external coil right? So I'd just order the external one and be done with that, in that aspect.
#108
Premium Member
I told you once, you make the engine work with the car and not the other way around. You need to figure out which one your car has from the factory and order that style for an H series so it will just plug and play. Just pop the hood and look. If you have 5 plug wires, one of which goes to an external coil, you buy an external coil OBD1 H22 distributor. If you have just 4 plug wires, it's internal coil and you need an internal coil OBD1 H22 distributor.
#109
#110
Would this be the kind of coil I would need?
http://www.ebay.com/itm/IGNITION-DIS...N7eG2w&vxp=mtr
It says for H22A1 distributor, is that compatible or no?
#111
td60u is the internal coil for the obd1 prelude vtec and td61u is the external coil for the obd1 prelude vtec
you need the external coil one so you need the td61u which is the one in that listing
#112
out of curiosity, would anybody know if my current ECU would be ok to use? If its useable at all? Because I dont have the information for what im going to do with the motor in order to order the tuned ECU from phearable.net. So would it be ok to use it as a temporary thing?
#113
you should just get an obd1 p13 ecu
#114
Does this look like the right part and do you think the price is fair?
Chipped OBD1 VTEC ECU P72 P13 H22a H23a GSR IAB p28 socketed | eBay
#115
Premium Member
OBD1 P13 ecu will not run the H23A correctly. The engine will run but it will have dangerous lean spots and be down on power because of that. Do not buy one and expect it to work. I've seen this firsthand.
Buy a chipped ecu from phearable or xenocron like I said, and wait until you're ready to do it. Those chipped ECU's on eBay are usually sold without having some things replaced that should be which can cause issues down the road. I know phearable and xenocron replace those so the premium you pay is worth the piece of mind. Don't try to cut corners as it will always come back around to you.
Edit: appears the one linked claims to be "rebuilt". I would inquire about what exactly they have replaced to confirm that before purchasing.
#116
#117
Premium Member
That's why you should wait. Or figure out the entirety of your setup now. They need to know that stuff so they can make a proper base calibration to get you to a tuner. If it's just going to be a basic setup, tell them that. You will probably need to buy some fuel injectors to be on the safe side so they will need to know what you're running for those also. DSM 390s should be plenty and will plug and play with your Accord. 440s may be a little much but it leaves you with room to grow. I believe the H23A comes with obd2 style 345cc injectors which will not be a direct fit and may run out of steam when the engine is brought to it's true potential depending on their condition.
#118
#119
Premium Member
The ECU has to be properly calibrated for the engine aka tuned...Otherwise catastrophic failure is a very real possibility. One wrong setting in the ECU can mean the death of the engine. I cannot recommend driving on a basemap or some random ecu not setup for the engine. The H23A unfortunately never made it to the states so there are no "plug and play" solutions for it. It has to be done right or shouldn't be done at all. I've seen too many people try to do what you're doing and it never works. Ends up with engine failure or a bunch of other issues. The tune is not the thing to be cheaping out on, even temporarily. With that said, can you limp it along and get it driveable with something other than what's required? Yes. Should you? No.
If finances are to be considered then I think you should go back and think about an F23 swap instead. It will be much simpler and cheaper in the end. You get about the same torque just without the top end and it's a much easier swap without nearly as many little nuances or potential issues.
#120
#121
This is the information they are asking for me to provide, could you possibly help me with any information about the H23A that you may already know?
Screenshot by Lightshot
the information that I dont know would be the injector specs, the map sensor, what i would need to put in the engine details as well as the revlimit and vtec engagement point, and whether or not i should put yes or no for the disable oxygen sensor.
#122
Premium Member
You can always just give them a call or e-mail them. They will be more than happy to help you as they get paid to do so. I've tuned quite a few blue tops and usually they make the best power with VTEC engagement between 4800-5200 depending on a few factors. Rev limit, if you're keeping it all stock - set that around 7200 for the time being. You can have that altered by your tuner when you have the car tuned. Wouldn't disable the oxygen sensor, best to keep that if possible. Map sensor would be stock. Injectors are to be decided by you as I already told you some of your options. You will also need to tell them if you plan to keep IABs or remove them and things of that nature.
#123
pr0jektdc2
04-30-2003 12:32 PM
GSRwBOOST
06-25-2001 06:05 AM
