my honda accord won't start?????need help please!! - Honda-Tech
Old 03-25-2015, 01:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Old 01-10-2009, 04:29 PM   #1
chad olson's Avatar
Default my honda accord won't start?????need help please!!
i have a 1990 accord that ran fine for 2years but recently the car doesn't wanna start? but when it does start it does not rev past 3,000rpm?????please help me out???thanks
chad olson is offline   Reply With Quote
Old 01-10-2009, 05:20 PM   #2
P_Adams's Avatar
Default Re: my honda accord won't start?????need help please!!
Quote:
OK Chad, what do you mean by no start?
It will not crank? or
It cranks but will not start?
Did you notice any problems leading up to this point?
Is the "Check Engine" lamp on?
Is it limited to 3k in all gear ranges?
or just in 4/5th
Does it start to buck when you run up against the limited rpm?
P
P_Adams is offline   Reply With Quote
Old 01-10-2009, 07:15 PM   #3
chad olson's Avatar
yea it cranks but won't start????i notice it like a week before this problem that when i was driving the car that it will jerk and die???and yes the check engine lamp is on???yes it bucks when i run it to limited rpm????
Old 01-10-2009, 08:56 PM   #4
P_Adams's Avatar
Getting the code is your first priority. I suspect you've a sensor failure and the ecm has reverted to defaut values (often refered to 'limo home mode'
P
Old 01-11-2009, 12:07 AM   #5
I agree, get that code checked out first. But also check your engine to make sure it is getting spark and/or fuel. Start small and work your way up.
gonnatell1 is offline   Reply With Quote
Old 01-11-2009, 10:15 AM   #6
chad olson's Avatar
the weird thing is that i jumped the blue connector wire wit a papper clip to check the check engine lamp and the light does not flash at all ????how else would i check it?????
Old 01-11-2009, 10:47 AM   #7
P_Adams's Avatar
Assuming that your connector jump proceedure was correct, the ECM can't diagnose itself; which means you must start with...
An ECM.
This is tricky since the ECM's very seldom go bad by themselves anymore. It's most often something else that has effected them.
has anyone ever crossed the jumper cables while trying to start this car?
Old 01-11-2009, 07:54 PM   #8
chad olson's Avatar
may i ask wat a ecm is??? iam new at this???
Old 01-11-2009, 08:31 PM   #9
P_Adams's Avatar
The Engine Control Module
P
Old 01-12-2009, 10:02 AM   #10
ztinaldoz's Avatar
this can be the distributor.. its a well known problem on theese cars.. have changet id twice before myself..
ztinaldoz is offline   Reply With Quote
Old 01-12-2009, 10:28 AM   #11
chad olson's Avatar
where is the Engine Control Module at???
Old 01-12-2009, 12:41 PM   #12
P_Adams's Avatar
ECM is under the steel shield on the left.
If you've an automatic, the TCM is the bronze colored box on the right
P
Old 01-13-2009, 12:00 AM   #13
3rdgenprelude's Avatar
is the cel on when you jump the wires cuz mine wont do it until the comes on first
3rdgenprelude is offline   Reply With Quote
Old 01-13-2009, 10:30 AM   #14
chad olson's Avatar
so do you think i should start with a new ecu?????????
88 Honda accord stalling!!please help!! Dch2014 Classic Hondas 4 02-26-2014 08:08 PM
90 accord hard cold start help 66tempest Honda Accord (1990 - 2002) 4 01-05-2014 01:39 PM
2004 Honda Accord V6 Not Starting ckr96792 Honda Accord & Crosstour (2003 - Current) 2 11-21-2011 06:28 AM
2001 honda accord wont start need help!!!!! Ak_JDM19 Honda Accord (1990 - 2002) 2 11-16-2011 06:54 AM
my accord won't start i hear weird buzzing ..please help chad olson Honda Accord (1990 - 2002) 4 01-16-2009 03:40 PM
Tags
1991, 2001, 2002, 3000rpm, 96, 97, accord, check, cranks, engine, honda, light, limited, rev, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
