Old 03-25-2015, 10:02 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
My fuel pump install experience 94 accord ex
Old 09-23-2011, 12:53 AM
  #26
djbuck04's Avatar
Default Re: My fuel pump install experience 94 accord ex
Originally Posted by AsiAnVenOm
for honda and acura the fuel pump is usually under the seat...if you remove the seat you can see the fuel pump...much easier than get'n under the car and drop'n the fuel tank...
i hope so im about to change my pump on my 91 accord coupe
Old 02-09-2012, 08:07 AM
  #27
trailmaker's Avatar
Great site lots of good info...
How far is the fuel pump from the hatch under the seat? And which direction is the fuel fron the hatch?
Thanks
Old 01-24-2013, 12:40 PM
  #28
Darren Thiesen's Avatar
You guys work too hard. '94 Accord has no access panel for fuel pump. The one I'm working on has 360K on it. The fuel lines are too rusted to try dropping the tank. I just used my die grinder and cutoff wheel to open the Access panel that should have been there in the first place. Easy job now.
Everyone please remember when working with fuel always keep a high capacity fire extinguisher within arms reach.
Old 01-24-2013, 01:13 PM
  #29
mudpuppy4life's Avatar
^ lol thats what i have been thinking the whole time while reading this....i did the "cut aflap" trick on mine not too long ago
Old 01-24-2013, 02:23 PM
  #30
Quence's Avatar
I Just cut a nice square access right on top of the fuel pump on mine, been changing pumps just like civics after that.
Old 08-09-2013, 08:20 PM
  #31
bogle's Avatar
Hey, does anyone have a picture of where to cut? I have a 97 accord wagon. I guess it's similar to the 94 accord or whatever people have already cut. I have no immediate need to do it right now but it would be nice to know
Old 08-09-2013, 10:51 PM
  #32
NZXTInerTia's Avatar
I have cut two of them from about an inch up and towards the drivers side from the hole for the trunk liner pin. Drill a 1/2" hole and start cutting. You will see where you need to cut from there. So find that hole, go 1" back, and 1" (facing backwards) right.
Old 08-11-2013, 07:25 AM
  #33
ThomasG's Avatar
Good thread. I'll be doing this soon.
Old 08-11-2013, 07:35 AM
  #34
Lost Again's Avatar
Here is a thread with a pic or two:
http://www.hondaaccordforum.com/foru...-access-41535/
Old 08-11-2013, 09:23 AM
  #35
GhostAccord's Avatar
For the amount of time it takes to drop the tank, and yes maybe even replace any rotten lines..... that should be replaced anyway, I'll stick to dropping the tank.
I don't see an advantage of this. To cut up a perfectly good body to mickey mouse something that shouldn't need frequent replacement. By the time you remove the interior, cut everything out, replace the unit...and still have the possibility of breaking the rotten lines, then properly seal it back up. You save absolutely no time. If you do brake any lines you'll then have to drop the tank anyway.
Just my 2¢!
Big D'
12-21-2017 10:19 PM
94accord89B
06-16-2012 06:27 PM
eg:R
07-25-2007 05:49 PM
mozzandherb
09-29-2005 04:11 PM
ebp 99 si
05-02-2003 02:55 PM
Quick Reply: My fuel pump install experience 94 accord ex
