Old 03-25-2015, 10:02 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
My fuel pump install experience 94 accord ex
Old 06-28-2003, 01:04 PM
accordfreak's Avatar
Default My fuel pump install experience 94 accord ex
the walbro 255lph intank pump...
does honda not want us to change the fuel pump or what?.. but yeah here's my install..it was a pain but not even close to being as painful as the clutch install.. The pump is slightly louder.. not too noticeable..
i unclamped all the hoses connected to the tank, disconnected the wire from the trunk, unbolted the straps, and one thing i didn't do but should have done.. drain the damn fuel. pretty straight forward though
close up of the tank
comparing the new fuel pump from the stock one
new one installed
inside the tank
installed and somewhat cleaned.
after that.. raised the tank with jack stands, bolted up the straps that holds up the tank, and reconnected all the fuel lines... there's actually one hard line you have to torque down at honda specs.. i believe it's 37 lbs with teflon paste on the threads... enjoy
Old 06-28-2003, 01:27 PM
booja's Avatar
Default Re: My fuel pump install experience 94 accord ex (accordfreak)
is the walbro the same size as your stock one? my pump was like an inch or and inch and half bigger
Old 06-28-2003, 01:28 PM
RotaryBzzzz's Avatar
nice pictorial....I feel for ya' - I hate working with anything fuel related. It's just a mess...
Nice Job
Old 06-28-2003, 01:29 PM
iam7head's Avatar
Default Re: My fuel pump install experience 94 accord ex (booja)
walbro that i have it's about little long and fatter also, i have to cut the line to get it fit right.
6th gen dont need to "drop the tank" btw
carolinaACCORD's Avatar
Good write-up!
Yah, it's a little longer, but I think it just the way it's leaning in the pic.
Old 06-28-2003, 01:35 PM
Default Re: My fuel pump install experience 94 accord ex (carolinaACCORD)
yah the pump is a bit longer.. i didn't measure how much longer though
my fuel pump came with new a new line and clamps so it fits perfectly.
Old 06-28-2003, 01:39 PM
AsiAnVenOm's Avatar
for honda and acura the fuel pump is usually under the seat...if you remove the seat you can see the fuel pump...much easier than get'n under the car and drop'n the fuel tank...
Old 06-28-2003, 01:45 PM
Default Re: (AsiAnVenOm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsiAnVenOm &raquo;</TD></TR><TR><TD CLASS="quote">for honda and acura the fuel pump is usually under the seat...if you remove the seat you can see the fuel pump...much easier than get'n under the car and drop'n the fuel tank...</TD></TR></TABLE>
for my 94 accord, they're different than the civics and integs.. honda decided to give the 5th gen owners a headache. when i looked under the car without the tank, i couldn't find any potential hatches to access the fuel pump
not sure about the other generations though...
Old 06-28-2003, 06:54 PM
mrnicolas's Avatar
can you remove the fuel pump in a 4th gen without dropping the tank?
Old 06-28-2003, 08:29 PM
Accord94DX's Avatar
Default Re: (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">
not sure about the other generations though...</TD></TR></TABLE>
No, you won't find easy access in the trunk. You'll find it sitting on the shelf of your local hardware store:
Old 06-28-2003, 09:50 PM
im_the_teacher's Avatar
Default Re: (Accord94DX)
hahhah hey accrd94dx........u choose the hard way to do it. instead of easy way.......
like the guy before said,,,,,,u dun need to drop down ur fuel tank to change fuel pump...........u can access fuel pump under the rear seat.........i guess it is too late now............u could of ask honda tech how to do it............well, dis is for future references for others in here
Old 06-28-2003, 09:51 PM
Accord94DX's Avatar
Default Re: (im_the_teacher)
the opening in the back seat is for the sender, not the pump.
Old 06-28-2003, 09:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote">the opening in the back seat is for the sender, not the pump. </TD></TR></TABLE>
ding ding ding
Old 06-28-2003, 09:56 PM
Accord94DX's Avatar
ding ding ding
Us turbo accord guys know what it's about. Im the teacher needs to be schooled.
Old 06-29-2003, 06:11 AM
YeuEmMaiMai's Avatar
I'll second that.......
Old 06-29-2003, 09:39 AM
machine4321's Avatar
so you notice any differenc when you pout it in .......ive heard its a good mod
Old 06-29-2003, 12:44 PM
SearchBeforeUPost!'s Avatar
Default Re: (mrnicolas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnicolas &raquo;</TD></TR><TR><TD CLASS="quote">can you remove the fuel pump in a 4th gen without dropping the tank?</TD></TR></TABLE>
nope, you have to do the same thing. And its the same amount of pain as shown here.
Old 06-30-2003, 05:36 AM
iakona's Avatar
is it the same for the 4 door 5th gens? (the access panel is in the trunk instead of under the seat i believe)
Old 06-30-2003, 05:57 AM
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">is it the same for the 4 door 5th gens? (the access panel is in the trunk instead of under the seat i believe)</TD></TR></TABLE>
yes, its the same. the access panel that you can see in the trunk is for different parts.
Old 06-30-2003, 06:22 AM
btlfed1's Avatar
Default Re: (carolinaACCORD)
I am teacher needs to go back to school.
Old 06-30-2003, 07:47 AM
92hybridAccord's Avatar
Location: In the heart of the ghetto of the, Suburbs NYC
damn...i gotta make sure, my fuel level is about low to empty, cause i will be doing this along with the rail and regulator and filter in about a week or so...
thanks for the write up...good job!!!!
Old 06-30-2003, 10:24 AM
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">so you notice any differenc when you pout it in .......ive heard its a good mod</TD></TR></TABLE>
nope ... i put it in just because it is recommended by hondata.. and to make sure i have enough fuel pressure at WOT when boost hits.
Old 01-16-2009, 07:39 PM
accord_raffi's Avatar
do you still have the pics for this? i'm about to do it and just wanna look over it before i start
Old 01-17-2009, 09:38 AM
He knows where you live!
TheMuffinMan's Avatar
I believe Cali Luv just did this for his H22 build, you may want to contact him to see if he has pics of the process, With a thread this old I wouldn't count on them having the pics saved.
Old 01-17-2009, 01:40 PM
good call. i just didn't want to start a new topic on something that was basically answered already. i'll get in touch with him
Quick Reply: My fuel pump install experience 94 accord ex
