Is my fuel pump going bad? Here's the symptoms.
Old 11-30-2003, 02:14 PM
94JadeAccord's Avatar
Default Is my fuel pump going bad? Here's the symptoms.
My fuel pump just starting making some strange buzzing whining muffled sound when i turn the key to the on position. A couple of times it didn't make any noise at all and the engine was just turning over.
Any input would be nice.
Thanks...
Old 11-30-2003, 02:15 PM
WuWarrior's Avatar
Default Re: Is my fuel pump going bad? Here's the symptoms. (94JadeAccord)
a little noise when you turn the key to ON is normal. It's just priming up.
Old 11-30-2003, 02:23 PM
Default Re: Is my fuel pump going bad? Here's the symptoms. (WuWarrior)
It used to make a little noise when priming but now it makes aLot of noise.
Doesn't sound right. Sometimes no noise at all.
Old 12-01-2003, 07:07 AM
Elvis1977's Avatar
Maybe its your main relay!
Old 12-01-2003, 07:33 AM
JimBlake's Avatar
Default Re: Is my fuel pump going bad? Here's the symptoms. (Elvis1977)
I vote for a bad pump. A bad main relay wouldn't cause the pump to get MORE noisy.
How about a fuel filter that's gotten plugged up? Then even a good pump has to work extra hard against a blocked filter. But that doesn't explain why sometimes it just doesn't run at all.
ed4doorcivic
20
11-04-2009 03:55 PM
TweedZ
05-31-2009 02:06 PM
superbangkok
10-06-2006 08:46 AM
Fat Chick Magnet
08-29-2006 05:55 AM
td04civic
02-19-2002 06:00 PM
Quick Reply: Is my fuel pump going bad? Here's the symptoms.
