Power Steering Noise? help me
Car. 6th gen 2000 Accord lx 4cly 5speed. 90k
soo their is a noise that happens when i make a U-turn or hard turn with the car. its like a groaning noise/whining. The noise only happens when i make sharp turns or U-turns while on the accelerator.
does any only have any ideas?
Re: Power Steering Noise? help me
1. it could be a bad power steering pump
2 a bad power steering hose about to blow
3 or u might have to check your power steering fluid
and if u do put more power steering fluid make sure u use, HONDA power steering fluid in, i didnt put the right kind in that, and two days later, the hose blew.
ok i just flushed my power steering fluid with OEM honda fluid.
the noise is still their, again the noise is rubing/whining/groning noise that only happens when i make hard turns or u-turn while apply the gas pedal.
if i make hard turns or u-turn in neutral the car doesnt make any noise.
should i replace my power steering pump?
No. You need further diagnostics. Great job determining the noise doesn't happen when in neutral. That is very important.
Cars can make a TON of different noises. Describing the noise through text is no substitute for actually being able to hear the noise ourselves. It's like describing the color orange to a blind person.
Try changing your transmission fluid.
ill try to do my transmission fluid this weekend, since i was planing on doing it anyways. i hope this helps.
man oem honda fluid dont come cheap.
Are you talking Squeel? like Ball Joint Squeel when you turn?
If that's the case gets those changed asap, or you Wheel will separate and you may slide into your death.
Have you looked at the suspension components?
Tie-Rod?
Ball Joints?
Bushings?
Shocks?
Springs?
Wheel Bearings?
If the Power Steering is the issue, you should hear noise when you turn (every turn). That pump is always under pressure when you turn......
Tie-Rod?
Ball Joints?
Bushings?
Shocks?
Springs?
Wheel Bearings?
Tie-Rod?
Ball Joints?
Bushings?
Shocks?
Springs?
Wheel Bearings?
Tie-Rod?
Ball Joints?
Bushings?
Shocks?
Springs?
Wheel Bearings?
Still could be suspension components. My Balljoints when they needed changing only made noise under acceleration through a turn.
Phootbag, are you a mechanic?
CheezeFrog
11-18-2019 11:11 PM
Inextricabledrvr
03-18-2009 07:56 PM
Elvis1977
12-16-2003 07:46 PM
