Map light, dome light went out. Possible Fuse? - Honda-Tech
Old 03-25-2015, 01:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
Old 07-25-2006, 11:08 PM   #1
uschonda's Avatar
Default Map light, dome light went out. Possible Fuse?
Hi Guys
I was stupid and changing the dome light on the roof with the light on. I was using a flathead and accidentally pushed it in too far.
When I did that the map lights and dome lights went out.
I'm thinking I burned out the fuse. Can anyone tell me which fuse it is and if its easy to replace?
thanks.
uschonda is offline   Reply With Quote
Old 07-26-2006, 01:51 AM   #2
0x5359-0055
213374U's Avatar
Default Re: Map light, dome light went out. Possible Fuse? (uschonda)
The fuse should be located under the hood. Very easy to replace.
213374U is offline   Reply With Quote
Old 07-26-2006, 12:09 PM   #3
510cd5's Avatar
Default Re: Map light, dome light went out. Possible Fuse? (213374U)
Quote:
yup should be a number 10. check your spare fuses on the drivers side and grab one of those.
510cd5 is offline   Reply With Quote
Dome Lights Out, but no Fuse Blown (?) EcoWhale Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 2 07-17-2015 01:56 PM
2000 civic si cluster dome light problem plz help.. H22tuner415 Honda Civic / Del Sol (1992 - 2000) 3 06-07-2010 09:06 AM
99-00 DOME LIGHT HELP! 550WHP boosted SI! HELP ME PLEASE!!! riddlinkid1986 Honda Civic / Del Sol (1992 - 2000) 9 09-09-2009 06:37 AM
Fried somthing? TravisCadello Honda Civic / Del Sol (1992 - 2000) 3 05-10-2009 06:34 PM
Interior Light Fuse Location Topnotcheez Acura TL, RL & ZDX 2 02-20-2007 07:04 AM
Tags
08, 1997, 2005, 2006, 97, 98, accord, dome, fuse, fuses, honda, light, lights, map, sedan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
