2000 Accord Engine Replacement, ULEV question
Hmmm, let's see. Long story short, my engine block is cracked and I'm buying a new one. The original motor is an F23A4 (ULEV) 4cyl LX with a manual trans. I'm replacing it with an EX motor, F23A1 (Non ULEV) and my question is about the compatibility of the ULEV head with the Non ULEV block. Can I put the original ULEV head on a Non ULEV block? Is it even possible to do this? I'm not 100% on the ULEV system so that's why I ask. Also, can a motor from an automatic go into a manual? Thanks. And no, I'm not going to just buy an H22.
Re: 2000 Accord Engine Replacement, ULEV question
Whether you're comparing ULEV to LEV, or automatic transmission to manual, the blocks and heads are identical. You'll have zero problems.
AndyD
11-06-2018 02:03 PM
01, 2000, accord, acura, automatic, engine, f23a4, honda, manual, motor, replacement, replacemnt, tl, transmission, ulev
