manual transmission fill plug (s)? - Honda-Tech
Old 08-18-2012, 08:49 AM   #1
Default manual transmission fill plug (s)?
Hi, I have a 91 accord wagon. I'm looking to change my trans fluid, but I'm not sure which plug to fill from? I have read the faq and searched, but my trans seems different.
Here are some pics. Drain?:
Fill?:
All three are square holes, no sign of a hex head.
Also, I have a couple bottles of redline MT90 in the garage, I haven't heard much about using this, I understand the Honda MTF is good, but I have no other use for the MT90... What do you think about using this fluid?
91 Wagon is offline   Reply With Quote
Old 08-18-2012, 02:31 PM   #2
djkurious's Avatar
Default Re: manual transmission fill plug (s)?
You have the fill and drain bolts correct. I personally use Honda MTF, but over on Acurazine, the folks there swear on the Redline fluid for their auto trannys.
djkurious is offline   Reply With Quote
Old 08-18-2012, 06:47 PM   #3
Which is the fill? My hand is pointing at two
Old 08-18-2012, 07:55 PM   #4
djkurious's Avatar
IICR, Fill is at the top, second pic where your 1st finger is pointing. Drain is at the bottom.
Old 08-18-2012, 10:57 PM   #5
In the second pic, the fill plug is the bottom one. Obviously, the drain plug is the one at the far bottom.
holmesnmanny is offline   Reply With Quote
Old 08-19-2012, 08:30 AM   #6
Quote:
Quote:
Just me here but the fill plug is actually seen in the first pic....
You can just see it, rear of the CV shaft.
Lost Again is offline   Reply With Quote
Old 08-20-2012, 02:51 AM   #7
Oh, so what am I pointing at in the second pic?
Old 08-20-2012, 03:13 PM   #8
Sealing bolts....#34 and #35 in this pic......not the fill hole for the trans.
The upper sealing bolt "seems" close to the true fill bolt but is higher IMO, so if you don't want to follow the proper procedure and us it.....good luck. Overfill your trans - it is your car. I'd use what the factory wants you to use.
EDIT: Which is #41 in the pic and the same as posted before. again, your car......do as you please.
Honda Accord ROH (rotor over hub) setup 91 Wagon For Sale 4 04-19-2015 06:39 AM
CA Desmond Regamaster EVO Wheels 4x100 josemig007 Wheels 3 08-24-2011 03:05 PM
Desmond Regamaster EVO Wheels 4x100 josemig007 Southern California (Sales) 2 08-23-2011 11:31 AM
FS: Hyper Rev Books Tyrant_007 For Sale 1 06-23-2010 02:13 PM
ek parts 4 sale b20_85 Southeast (Sales) 0 10-22-2008 09:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
