lug nut thread size? - Honda-Tech
Old 02-16-2006, 12:13 PM   #1
drktorn's Avatar
Default lug nut thread size?
what thread size are the honda lug nuts?
are they 12x1.5
drktorn is offline   Reply With Quote
Old 02-16-2006, 01:28 PM   #2
P_Adams's Avatar
Default Re: lug nut thread size? (drktorn)
12x1.5
better known as 12mm x 1.5 pitch
P
P_Adams is offline   Reply With Quote
Old 02-16-2006, 04:24 PM   #3
iam7head's Avatar
Quote:
are they 12x1.5
round seat for stocker, taper for aftermarket
iam7head is offline   Reply With Quote
Old 02-16-2006, 04:44 PM   #4
drktorn's Avatar
Default Re: lug nut thread size? (P_Adams)
thank you sir.
Old 01-24-2013, 09:00 PM   #5
My frontcar left wheel on my 99 Accord EX flew off today while driving 70mph. No idea how but all the studs are intact except 1which is bent over so I'm replacing all studs are need to buy lug nuts and wasn't certain which style was correct for stock aluminum wheel. I know the size I just wondered til I saw this post. Thanks.
cattafin is offline   Reply With Quote
Old 01-24-2013, 09:15 PM   #6
Is it necessary to retorque lug nuts after first 50stock miles or so? I ask because my wheel flew off today and I had done the front brakes 10 days ago and I know I torqued them to 82lbs,I guess it's also possible that I didn't have the wheel lugs seated properly before I let the jack down and did final torque. I'd have expected the studs and/or theholes in the rim to be mangled but they're not. Only 1had stud is bent. It was making a heck of a racket before the wheel flew off but I thought it was the plastic cover under the front end hanging down and rubbing on drive axel. Boy was I wrong.
OFFICIAL LUG NUT PICTURE THREAD Jeezer Honda / Acura 1168 05-04-2016 08:03 AM
lug nut thread size questions 94DCTeg Acura TSX 4 03-31-2010 12:42 PM
Lug nut thread type 5genprelude Honda Prelude 3 01-31-2007 02:23 PM
lug nut ? mountaindewguy Honda Civic / Del Sol (1992 - 2000) 4 05-07-2005 06:30 PM
Lug nut size dustin Acura Integra Type-R 9 02-14-2002 03:18 PM
Tags
90, 96, accord, civic, ef, honda, lug, lugnut, miata, nut, pattern, pitch, s2000, size, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
