Calling all 94-97 ACCORD owners or Honda Buffs?
Old 11-01-2010, 06:41 AM
tommyhondacar's Avatar
Default Calling all 94-97 ACCORD owners or Honda Buffs?
I had a question. The A/C temp ***** on my accord are giving me problems. The heat/cold **** feels like it has resistance and does not just turn on a dime like in my 02' accord. (Not sure if this is normal). Also though all levels of the A/C work, it seems the **** will activate to "4" but go past "4" and turn off completely. Not sure if this is a fluke or common problem.
Any input?
Thanks
Old 11-01-2010, 07:05 AM
ilikehonda's Avatar
Default Re: Calling all 94-97 ACCORD owners or Honda Buffs?
Normal. Go to the honda dealer and they will give you two tiny metal sleeves to go inside the ****. it will keep the ***** from stretching and breaking.
They all do this. as soon as i did this problem solved.
Old 11-01-2010, 08:45 AM
How much are these "sleeves"? Would they know what I am talking about if I went and asked, is it that much of a common problem, or just an annoyance factor?
Old 11-01-2010, 08:51 AM
19Accord97's Avatar
Yup, the temp **** is stiff. Like the other guy said, they commonly break during cold weather b/c of the resistance.
Old 11-01-2010, 08:58 AM
I am reading forums about some cables. Honestly, I never adjust the temperature **** because, it is rarely cold here. But now that Winter is approaching, I don't want the Heat to die. When I did feel resistance I slowly adjusted the settings.
So basically what you are saying is that it's really an issue of keeping the ***** from breaking and in reality the resistance issue can't be corrected?
Old 11-01-2010, 09:03 AM
19Accord97's Avatar
Correct, the cable is fine and shouldn't break. Just turn the **** slowly and you'll be fine! I didn't know about the metal inserts, but since I had ***** break on me before I took them off and zip-tied 3 small zip ties around the plastic to support it and keep it from breaking.
Old 11-01-2010, 10:07 AM
ilikehonda's Avatar
the cable is an expensive fix. the entire dash has to come out. The cable is fine just stiff.
if i remember right the sleeves were free. I just had to go get it.
valley4130
07-31-2009 06:04 AM
greenzchatch
01-16-2009 10:26 PM
rshlain
09-17-2004 07:38 PM
Quick Reply: Calling all 94-97 ACCORD owners or Honda Buffs?
