Low beams dont work, but high beams do - Honda-Tech
Old 12-10-2005, 11:02 AM   #1
Willdrumforfood1's Avatar
Default Low beams dont work, but high beams do
Hey Guys heres the story behind the problem. My low beams went out on my 97' Honda Accord so I bought a new bulb for it. I was told to buy the 9006 model number but that didnt fit, so I went back and bought the 9005 to try it. It fit but now neither low beams work, althrough the high beams both work fine. Any ideas on the problems? I already checked all the fuses and replaced them to no avail. Could it be a problem with the headlight switch? Maybe I bought the wrong model number? Thanks guys and sorry for the newb post.
Willdrumforfood1 is offline   Reply With Quote
Old 12-10-2005, 11:12 AM   #2
RiceRocketDave's Avatar
Default Re: Low beams dont work, but high beams do (Willdrumforfood1)
Double check the fuses....I had a similar problem on mine and thought all the fuses were fine but they weren't. There are three 20A fuses under the hood that you need to check. Also the 9006 bulbs are the ONLY bulbs that will fit in the low beams . Double check the bulbs to make sure that they are still ok and not burned out.
RiceRocketDave is offline   Reply With Quote
Old 12-10-2005, 12:14 PM   #3
Default Re: Low beams dont work, but high beams do (ricerocketdave)
hey thanks..turns out I was replacing the high-beams instead of the burnt out low-beams. All fixed now. thanks
Old 12-10-2005, 12:27 PM   #4
no problem
Old 12-10-2005, 01:07 PM   #5
P_Adams's Avatar
[quote]
"..turns out I was replacing the high-beams instead of the burnt out low-beams. "
P
P_Adams is offline   Reply With Quote
Old 12-10-2005, 01:17 PM   #6
greasmanky's Avatar
Default Re: Low beams dont work, but high beams do (P_Adams)
pics now
greasmanky is offline   Reply With Quote
Old 12-10-2005, 04:58 PM   #7
Me Gusta History
accordselux's Avatar
Default Re: Low beams dont work, but high beams do (greasmanky)
Quote:
Originally Posted by greasmanky
pics now
I swear, you say the most random things and I have no idea waht to do with you.
accordselux is offline   Reply With Quote
Old 12-10-2005, 05:28 PM   #8
BLKFLSH's Avatar
What do you want pics of?
BLKFLSH is offline   Reply With Quote
Old 12-11-2005, 12:57 PM   #9
hondadude's Avatar
Default Re: Low beams dont work, but high beams do (BLKFLSH)
Quote:
Hot babes doing the ***** a zontal boogie
hondadude is offline   Reply With Quote
passenger side low beam not working standerby Honda Accord & Crosstour (2003 - Current) 1 10-29-2016 04:31 AM
HID problem bryan24207 Acura Integra 45 01-10-2012 08:31 AM
headlight/ high beam problem Evan125 Honda Civic / Del Sol (1992 - 2000) 5 12-07-2009 09:00 PM
High beams work low beams do not eghatchin Honda Civic / Del Sol (1992 - 2000) 16 04-25-2008 05:46 PM
high beam problem combustion Acura Integra 2 08-20-2002 10:54 PM
Tags
2003, 2004, accord, beams, cooper, coper, coupe, dont, g35, high, honda, low, mini, pilot, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
