loud sound from engine, maybe hole in exhaust manifold?? - Honda-Tech
Old 08-01-2007, 01:02 PM   #1
show_time's Avatar
Default loud sound from engine, maybe hole in exhaust manifold??
I jus got a 1990 honda accord exr, that first gave me trouble with a leak in the stearing fluid, and maybe a hole in the exhaust manifest. I dont kno much on repairing this vehicle, but i was wondering on what the symptoms would be of a hole in the exhaust manifold, there's also smoke coming from that area. Please help , thanks
Salah
show_time is offline   Reply With Quote
Old 08-01-2007, 01:08 PM   #2
F23Coupe's Avatar
Default Re: loud sound from engine, maybe hole in exhaust manifold?? (show_time)
Easiest check is to put a piece of paper around the exhaust manifold when the engine fan is not blowing. Then rev. it up and you should see it. Also, you can tell by sound alone. Jack it up and try to locate the sound while someone rev's the engine.
F23Coupe is offline   Reply With Quote
Old 08-01-2007, 01:09 PM   #3
bseriescrxsi's Avatar
hole in exaust manifold(headers) will produce a real horrible smell if the hole is b4 the converter under the car...if you smell that...fix it asap...dangerous smell
bseriescrxsi is offline   Reply With Quote
ITR Wing..same mounting holes as LS wing? OMG THE GOGGLES Acura Integra 6 03-17-2006 07:05 PM
hole in tranny sLoWrAcEr Honda Civic / Del Sol (1992 - 2000) 11 02-26-2005 01:15 PM
Stock Holes for Strut bar on Stock DX Soda Popinski Honda Civic / Del Sol (1992 - 2000) 3 02-22-2005 07:42 AM
92 Accord LX has a hole in the Exhaust Help? omrider Honda Accord (1990 - 2002) 3 11-30-2004 08:26 AM
How much oil between holes on the dipstick? R-Type Acura Integra Type-R 32 07-24-2003 11:09 AM
Tags
accord, check, engine, exaust, exhaust, exhuast, hole, honda, loud, louder, manifest, manifold, noise, sound, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
