Loud Screeching Noise when starting Car? - Honda-Tech
Old 06-12-2007, 10:36 AM   #1
bsivoljr's Avatar
Default Loud Screeching Noise when starting Car?
Sorry guys Im a Newb but I learn fast, Just never had a car until about a month ago.
Never had one to deal with ya know, finally bought one Independently. Saved up the money. 1990 Accord Lx.
I bought a problem, but I know you can work Magic with Hondas. Well what Im trying to figure out is How come when I start the car it screeches for about 30 seconds. Since I bought it every day it screeches longer and longer when I start it up. At first it was only like 3 seconds. When I step on the gas it stops screeching faster. When I have driven it, turn off, then start again. If not too long since last time running, it screeches for about 5 seconds and when I step on gas it stops. I know your thinking the belts but when I look at the belts they have no visible cracks? or obvious ware inside or out. When I spray belt dressing on them, it sounds a little better, and stops faster. Do you think they are loose?
bsivoljr is offline   Reply With Quote
Old 06-12-2007, 11:13 AM   #2
jdadams12's Avatar
Default Re: Loud Screeching Noise when starting Car? (bsivoljr)
It is most likely the belts still. You can also get this of any of the accessory bearings are going out - like AC Clutch, PS Pump or Alternator.
Does this happen even when the AC is off? If so, then I would look elsewhere than the AC/Alternator belt.
jdadams12 is offline   Reply With Quote
Old 06-22-2007, 12:18 AM   #3
bsivoljr's Avatar
The AC doesn't even work
Old 06-22-2007, 12:44 AM   #4
pos_cd5's Avatar
Default Re: (bsivoljr)
if belt dressing didnt help try tightening the belts. IIRC there should be a belt tensioner for the serpentine belt. if not...then replace the belt.
pos_cd5 is offline   Reply With Quote
timing belt problems? jongme23 Tech / Misc 3 06-28-2007 08:51 PM
Finally replaced timing belt..but, eg6_rick Honda Accord (1990 - 2002) 7 09-17-2006 12:51 PM
Belts making CHAINSAW screeeeeeeching noises at start up, this is pissing me off! Draggin99Si Honda Civic / Del Sol (1992 - 2000) 8 01-20-2006 05:48 AM
Start Car, screeching sound....? Civiclx Honda Civic / Del Sol (1992 - 2000) 11 11-17-2003 09:56 PM
Screeching from one of the belts qwklude82 Tech / Misc 4 01-08-2003 11:26 AM
Tags
car, coming, gas, honda, loud, noise, noises, screech, screeches, screeching, skreech, staring, started, starting, startup, step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
