looking for a 96 accord lx ground points??
Old 11-07-2006, 12:10 PM
01celica_gts's Avatar
Default looking for a 96 accord lx ground points??
does any have a diagram or a description of all the grounding points for a 96 accord lx?? i'm trying to determine if the car has a bad ground somewhere.
Thanks
Old 11-07-2006, 07:51 PM
hondadude's Avatar
Default Re: looking for a 96 accord lx ground points?? (01celica_gts)
Could you elaborate a little bit on what kind of problem you are having.
Thats a lot of work to scrounge up ALL ground locations with pictures.
Old 10-29-2015, 11:48 AM
joezmam367's Avatar
I know this is an old post but figured I'd bump it
Im in a 96 accord lx and having a misfire, and was told to check engine grounds.
I know, teh one on the valve cover is good, as well as the one on the intake man, tranny housing, pass side frame(just by the headlight), alt mounting bracket.
am i missing an important one somewhere?
Old 10-31-2015, 05:56 AM
poorman212's Avatar
G101 is on the drivers/left side of the plenum - this is the main ground for the ECU.
Old 10-31-2015, 10:54 PM
holmesnmanny's Avatar
The main one you need to look at is the one poorman mentioned. Take it off and make sure it is clean and the plenum portion is clean as well. It's unlikely that is the reason for your misfire though.
Misfires can also be caused by the spark plugs, the distributor rotor, the cap, and egr ports being dirty.
Old 11-02-2015, 03:08 AM
joezmam367's Avatar
im not exactly sure what you are referring to as a plenum, but the ground that i found labeled as G101 should be the one on the end of my intake manifold, as far as google led me to believe. i know that ground is good and clean.
i got rid of the mis for a while this weekend by pulling the connecters on the cheap wires and i think i just have a bad connection in there, so i ordered NGK that should be here wed. hopefully that's it, just a simple fix.
Wrens
06-10-2015 11:48 AM
Nassrif
05-06-2014 04:24 AM
shadydb7
Northeast (Sales)
11-16-2009 11:52 AM
Quick Reply: looking for a 96 accord lx ground points??
