leaking oil out of oil sending unit! - Honda-Tech
Old 02-05-2009, 04:15 PM   #1
Icon6 leaking oil out of oil sending unit!
so should i use some type of thread seal to stop leak?
dirk digler is offline   Reply With Quote
Old 02-05-2009, 04:30 PM   #2
P_Adams's Avatar
Default Re: leaking oil out of oil sending unit!
Quote:
No. replace the sender.
If you want to; use some teflon tape on the threads, but the sender is your problem
P
P_Adams is offline   Reply With Quote
Old 02-08-2009, 08:55 AM   #3
P
Any instructions or pics to do this? The manual I got is so vague and not include this procedure in it.
Thanks.
Bad_dude is offline   Reply With Quote
Old 02-08-2009, 11:56 AM   #4
hondamark35's Avatar
it's very easy once you find a socket to fit the sending unit.
pull the lead wire off, (it can be stubborn so don't give up too soon.) unscrew the sending unit and replace with the new one...
i like to use gray RTV on the threads, but PTFE (teflon) tape will work, the threads are tapered pipe threads-just FYI.
this is easiest to do durring an oil change while the filter is off so that you have easy access.
hondamark35 is offline   Reply With Quote
Old 02-08-2009, 12:01 PM   #5
P_Adams's Avatar
Quote:
Thanks.
Get a new Oil Filter
Remove old Oil Filter to gain access and room to move.
3/8" drive 6 point 22mm deep Socket or specialty Oil Sender Socket
3/8" Drive Ratchet. 6 or 9" handle
Disconnect wiring harness
Remove Leaking Oil Pressure Sender Unit
Reverse proceedure
Congratulate yourself
P
Old 02-09-2009, 12:34 AM   #6
It properly sound easier if you guys do it. I am still chicken to adjust my valves.
Old 02-18-2009, 08:52 PM   #7
What does the oil sending unit looks like?
Thanks.
Old 02-18-2009, 09:10 PM   #8
redbull-1's Avatar
Thanks.
redbull-1 is offline   Reply With Quote
Old 02-19-2009, 11:42 AM   #9
So it's a switch rather and right above where the oil filter is plug in.
Thanks for the pic.
Old 03-01-2009, 07:17 AM   #10
Reverse proceedure
P
Hi,
Will the oil pour out when removing the send unit? Do I need to do the oil change after that? So teflon is good enough or does it have to be Hondabond type? Where can I get the oil send special socket? What so special about the socket? Is it b/c it has that center slit on the side for the lead?
Thanks.
Old 03-01-2009, 01:53 PM   #11
I would say that a small bit would come leaking out but no flood like pouring out of oil as if you opened the drain plug.
If you are near enough to a oil change then do so, if not simply top the oil off
The parts store should have a socket for the sending unit but i would think simply using a deep socket would work the same way.
I have not done much work on Honda's but I have worked a lot on GM and Ford engines and every oil sending unit I have replaced the original (factory installed one) came with red thread lock on the sending units threads. I don't know if on Honda's you can do this or not
Good luck
L
journeyforce is offline   Reply With Quote
Old 03-01-2009, 05:42 PM   #12
I have found the special socket for $3.99 plus 20% off. Guess what? I found it at the store I work at HarborFreight Tools. The item number is 95046. The problem is that, now there's no more leak from my car and I have been driven it all day today. No leak either after or during park. I guess, it's like last time when I change the gasket in my distributor. The leak is probably from the cleaning I did after changing the valve cover gasket. It's been pooling and finally comes down from the engine heat. Never the less, no oil loss at I have been checking and no more drips. I'll be watching it for the next few months.
Here's the link: http://www.harborfreight.com/cpi/cta...emnumber=95046
Is that the one I can use?
Thanks,
95 accord ex vtec oil leak unt37 Honda Accord (1990 - 2002) 3 05-23-2014 08:15 AM
oil leak mononina22 Honda Accord (1990 - 2002) 1 10-11-2013 04:09 AM
Gsr dizzy cap leaking oil mien_civic715 Honda Civic / Del Sol (1992 - 2000) 8 10-22-2010 09:41 AM
ls/vtec oil leak gshatch Acura Integra 5 05-06-2008 01:06 PM
Oil leak for 1994 accord ex vietkangta Honda Accord (1990 - 2002) 2 09-21-2006 10:21 PM
Tags
38, 95046, 96, accord, freight, harbor, honda, location, oil, plugging, sender, sending, socket, tape, tefflon, unit, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
