1998 Honda accord oil mixing with coolant still after gasket change!! Help or advice!
Old 08-21-2010, 06:33 AM
Hondapreludeg's Avatar
Default 1998 Honda accord oil mixing with coolant still after gasket change!! Help or advice!
I have a 1998 accord with a 2.3 ULEV 4cylinder motor and it has 127k on it. I bought it and the oil was mixing in the coolant system. I replaced the head gasket head bolts and had the cylinder head machined. The problem came right back. What else could it be?? Should I just replace the gasket again? Any help would be appreciated??
Old 08-21-2010, 07:12 AM
be professional
Targa250R's Avatar
Default Re: 1998 Honda accord oil mixing with coolant still after gasket change!! Help or adv
You're definitely not the first person to have this problem, and won't be the last - I've seen it happen at least a dozen times. The problem isn't the head gasket. You likely have a cracked sleeve, block, or head. I never recommend replacing head gaskets with the F23A4; they're a bit notorious for this problem. You should have just replaced the whole engine from the start. You can often pick up a complete used engine from a local salvage yard with a 6-month part-only warranty for as little as $250.
Old 08-22-2010, 03:12 PM
joe_accord23's Avatar
u have a block problem, its cracked, it causes the oil to join the antifreeze. or it could be a cracked head. chk her out!
Old 08-23-2010, 05:26 AM
How can I figure out whether it is the head or the block? Thanks guys~
Old 08-24-2010, 12:51 PM
take the head off and look to see inside the cylinders if there is antifreeze in there,and check if there is oil in the water jackets....u have cracked head/block!
benphillips
05-04-2013 07:37 AM
turbomike
01-19-2010 08:27 PM
lesterruckfort
09-14-2008 07:52 PM
rc90hatch
01-10-2006 05:49 PM
preludeguy_92
05-23-2005 06:39 PM
Quick Reply: 1998 Honda accord oil mixing with coolant still after gasket change!! Help or advice!
