Interchangeable ecu?
Old 03-19-2017, 08:00 PM
Zfracing's Avatar
Default Interchangeable ecu?
Wondering if there is a way to change my ecu so I can run hondata I have a 2002 Accord f23a
Old 03-20-2017, 01:31 AM
GhostAccord's Avatar
Default Re: Interchangeable ecu?
Your stock OBD2 ECU cannot be modified to accept Hondata. You would need to purchase an OBD2 to OBD1 harness and an OBD1 (Civic/Integra) ECU modified, chipped, for the Hondata hardware.
Old 03-20-2017, 06:47 AM
Zfracing's Avatar
thank you! One more question when you say ecu modified I can't just buy a stock ecu? Then put the hondata chip in myself? Sorry I'm new to this I've never messed around with ecu.
Old 03-20-2017, 01:41 PM
If you are familiar with soldering resistors, chips and other electronic components onto a circuit board, you can chip an ECU yourself. I did my own and quite a few others since then.
PGMFI.org is a good place to learn about OBD1 ECU's and the modifications that can be done to them. Hondata.com also has a good ECU tech section.
Najdmitr307
Engine Management and Tuning
10
03-10-2009 03:18 PM
JDM turbo DC
10-11-2005 01:10 PM
tub_sephiroth
11-18-2004 10:27 PM
NuclearB18B
09-19-2003 04:15 PM
integranator
03-02-2003 09:45 AM
Quick Reply: Interchangeable ecu?
