Instrument Panel lights?
Old 07-17-2007, 07:29 PM
finaldude's Avatar
Default Instrument Panel lights?
Hi, I'm having a problem (just like everyone else on here ) with my 99 Accord LX that I can't figure out and it really bothers me, because I've
been trying for a few days now and I'm not getting anywhere. My dashboard/instrument panel lights are not working at all. Other people have had
the same problem, however if those lights are not on something else is not working as well. In my case though everything else is working just fine.
turn signals, dome lights, window controls, break lights, parking lights everything. What's weird is that when my headlights are off the clock and the odometer
lights are on, when i turn the headlights on though they go off. The light in the glove box is working when i turn the headlights on.I've checked all the fuses, the wiring (as good as i could) and I can't find anything
wrong. I did mess with the car a little bit but I wasn't even close to doing anything with it's wiring. I installed a power supply for my carpc
but all I did was to run a wire from the + on the battery to the PS and ground it. I also replaced the light bulb on the clock with one that I pulled
out of a different AC control unit. The bulb was a bit bigger but still worked. I also put in a Sony CD Player. I have ordered a multiplex unit, but I'm not sure that that would fix
the problem. If the multiplex unit is bad shouldn't I have other problems as well? Could it be the dimmer switch? I think that's where I should've started
before ordering the multiplex unit, but I guess I don't have to buy it from the dealership. Any ideas? Has anyone had the problem before? Any help would be appreciated. Thanks
street_racer_271
05-03-2017 04:10 PM
areed404
06-15-2012 08:25 AM
skimeast1982
Audio / Security / Video
10-22-2005 11:33 AM
ttrinh77
01-03-2005 06:45 PM
ChargedLude97
13
02-12-2004 01:57 PM
Quick Reply: Instrument Panel lights?
