Idle adjust info - Adjustment idling low IAC
Idle adjust info - Adjustment idling low IAC air control
I posted this in another forum and thought it might be of some interest here.
[Modified by niedejb, 11:34 AM 11/29/2002]
Originally posted by niedejb
Pull the idle air control plug (on the back of the manifold looking from the drivers side) after the car is warm with all accesories off.
There is a slotted screw on top of the throttle body that you can turn in and out to adjust your idle.
Plug the IAC back in and reset the ecu (youll get a check engine light) by pulling the 7.5 amp radio backup fuse under the hood.
Re: Idle adjust info - Adjustment idling low IAC air control (civicwagonman)
Back out the screw on the throttle body a couple of turns and it should stay running.
Make sure you only do it after the engine gets to normal temp.
Re: Idle adjust info - Adjustment idling low IAC air control (niedejb)
just turn the screw and not adjust the whole housing??
phillips type screw. like your headlights? one way is one thing another is another?
Re: Idle adjust info - Adjustment idling low IAC air control (KTeller8)
great once i get out of this darn spreadsheets class i am to the parking lot to fix that
New User
ill go look, i though it was in the same spot, nontheless its somewhere on the intake manifold trace the coolant lines its right after the FIV i believe
New User
Re: Idle adjust info - Adjustment idling low IAC air control (ArchAngel Sabastian)
it might be on the front like the h23 (IAC - center of the pix 2 10mm bolts one connector under the throttle cable )
[Modified by ArchAngel Sabastian, 7:14 PM 12/6/2002]
thanks i ll have to check it out
anyone have diagrams or know where they are online for vacumm hoses? i have a leak and need to start somewhere..
Start at the intake manifold where they all come off the end. They all start there.
i have a 91 accord with f22a4. I found the wiring plug to unplug but when i went over to the other side i didn't find that slotted screw to adjust. There is a hole with some sort of plug in it. Maybe i have to dig the plug out or something. anyone know about this? thanks
Re: Idle adjust info - Adjustment idling low IAC air control (cyrixvsp2)
ya its on the TB above the intake inlet,, you might have a grey looking film over it. kinda like what a watch has on it.. to protect the glass. just get the scewdriver and scrape it out
now for me? i turned the screw this way and that. and nothign. i had no effect? whys that?
thats the way mine is, makes no difference moving the screw. I can take it all the way out and it does'nt do much.
not the same for the H22 is it <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emsad.gif" BORDER="0">
anyone know bout the IAC on the h22
OK...I'll ask you too.....
Even with the IAC unplugged?
ya i can pull it all the way out and even with the IAC unplugged
when i pull the iAC i have a harder time getting the car to say on.. i need someone in the seat turning the key..
What year is your car? Will this work the same as on a 1991 Honda Accord EX ?
I would like to adjust my idle up to if it's as easy as you describe... Also what sould the idle be set at ? Do I do it in gear or in park? It idles around 500 RPM ... I would like it up around 800 to avoid the vibration that comes with the low idle speed.
Thanks,
Branden
kb9wee@hotmail.com
[Modified by big b 911, 8:01 AM 2/12/2003]
Thanks,
Branden
kb9wee@hotmail.com
Re: Idle adjust info - Adjustment idling low IAC air control (big b 911)
Its a 97. Not sure about the 91.
I'd do it in park so you dont have to chase it around the block.
The target idle is up to you mine saays 550rpm with no load.
