icm or main relay or timing?
Old 12-16-2011, 08:57 AM
my1992cb7accord's Avatar
Default icm or main relay or timing?
ok the other day my car just quit working, its a 1992 honda accord lx. had a friend (whos a mechanic) come over and tested the spark plugs with a timing light. he said that it had spark but a very weak spark and said the ignition coil was bad, so i went and replaced that and tried starting it up nothing. it didnt start. so i went all out and went ahead and replaced the distributor cap, rotor. spark plug wires and spark plugs. tried starting it up and now have absolutely no spark. could it be the icm in the distributor as it makes it spark? or the main relay as hondas always have trouble with them or could it be that the timing belt broke/chiped a tooth and got off. but if it was the timing wouldnt it still spark?
Old 12-16-2011, 09:15 AM
Default Re: icm or main relay or timing?
i believe i ruled out the main relay as it is part of the fuel which the car is getting cause i smell it and hear the pump turning on when i turn the battery on
Old 12-16-2011, 10:16 AM
anyone?
Old 12-16-2011, 12:22 PM
StreetsideStig's Avatar
You're right about the main relay, I think. Have you tested the battery?
Old 12-16-2011, 02:25 PM
nus_dogg's Avatar
Check your intake manifold ground wire. If thats loose or corroded, it will not spark.
Old 12-16-2011, 02:47 PM
holmesnmanny's Avatar
I'd check for fuel just to be sure. And if that checks out I'd get a used igniter from the junkyard.
Old 12-16-2011, 06:00 PM
changed the battery terminals too, forgot to add that. wheres the intake manifold wire?
Old 12-16-2011, 11:16 PM
If you were getting no spark or regular colored spark that would be one thing. The fact that you're getting weak spart I believe should narrow it down to either the igniter or coil.
Old 12-17-2011, 03:19 AM
yeah next thing i guess i will try will be the icm
Herbie
04-21-2010 09:57 AM
DelSlowmo
61
02-12-2009 07:50 PM
faithypoo
01-11-2009 01:07 PM
widecrx
07-01-2007 05:14 PM
SkIp_Civic_Ek6
06-25-2006 04:54 AM
Quick Reply: icm or main relay or timing?
