I Need a SPARK!!!!
I Need a SPARK!!!!
As you all know...i'm doing an obd1 h22a1 swap into my obd2 96 lx accord. Basic swap until i get to the wiring....i've rewired the dizzy plug wires accordingly....i'm using the obd1 h22 dizzy right now and my accord harness..... there was no spark and neither the fuel pump was priming nor was the CEL working.....so i regrounded everything and it worked....
I redid the wiring for the dizzy and still no spark....the CEL works, throwing code 10 and 21 which is IAC and Vtec. The fuel pump is priming...so i'm assumiing i got all the grounds....I swapped ignition coils just to verify that it wasn't the ignition coil and the two wires, yellow and blk/yellow, are getting a signal...i tested em....
so now i'm left with basically....the dizzy is still not sparking even after i rechecked and rewired everything....i'm stumped...bad dizzy maybe?
anybody in So Cali have an obd1 usdm h22 dizzy i can maybe swap out just to try?
DigitalPunk
07-27-2013 12:53 PM
