Humming noise
Old 08-01-2015, 08:47 AM
lit549's Avatar
Default Humming noise
Ok,i have a humming noise from belts on a 3.0 v6..I've searched everywhere and all posts say it's either power steering or timing belt..Mineconly does it at idle,it goes away as ya rev it,turning steering wheel has no affect..I recently replaced oil pump due to oil leaks and I inspected everything..There was rubber collected around plastic cover like the belt has been rubbing..After further inspection,it isn't rubbing cover anywhere..One edge of belt looks to be rubbing raised edge of water pump pulley..The belt and pump have 3k miles on them..Its a mitsobishi belt and aisen(?) pump..I installed new oem tensioner while in there..I know this humming is coming from belt cause when I pull inspection plug from cover it gets louder..Any suggestions???
Old 08-02-2015, 11:00 AM
lit549's Avatar
Default Re: Humming noise
I've looked and looked and can't find it..I'm stumped..
Old 08-03-2015, 02:16 AM
slowcivic2k's Avatar
When did the noise start, and what was the last thing done prior to the noise appearing?
Old 08-03-2015, 07:26 AM
lit549's Avatar
That I can't tell you..I bought the car in December for my daughter..Its been setting till she can drive..it has 110k on it and is clean..It had oil leaks which ended up being the oring on oil pump and cam cap o ings..I replaced pump and resealed everthing,the timing belt has 3k miles along with water pump,all oem...It sounds like a pulley is rubbing the plastic cover,but I couldn't find any place where it is rubbing..Also,i replaced belt tensioner and a serpentine idler pulley,still has the sound..Oh,water pump and alternater both turn freely without any bearing noise..
Old 08-03-2015, 03:23 PM
poorman212's Avatar
For giggles, remove the serp belt and run the engine to be sure the noise is still there.......yes the alt won't be running but the wp will so just don't over do it but the car will be fine without the serp belt for a short period of time.
If it is still there....well then you know it is behind the covers and they will have to come off.
There are two "idlers/tensioners" there, inspect those for hard spots. Also there is a washer" on the crank where the concave should be facing out - is it?
Old 08-04-2015, 11:02 AM
beocop's Avatar
Mine had a humming noise around the TB area. The sound is pronounced when one of the inspection plug on the TB cover is removed. It turned out to be the timing belt. The sidewall of the TB belt was rubbing and there was some metal showing on the sidewall of the belt. I don't know why the sidewall rubbed off. At that time, the TB only had ~12K miles. With the new belt on, the noise went away and hasn't come back yet.
Hope this helps. Good luck.
Old 08-16-2015, 07:36 AM
lit549's Avatar
That's what I'm worried about,I was just in there too and couldn't see anything wrong at all..Everything is new you can tell,Now I wish I would have at least replaced the belt..I'm real curious as to why its wearing on one edge of belt?And as far as tension,its a auto tensioner,no adjustment..Guess I'm just gonna run it!
Old 08-16-2015, 09:53 PM
Ensure the timing belt guide plates on the crank gear are not installed backwards. Installing them backwards will result in the plate rubbing and tearing the belt up. There are two washers on this pulley. One behind, and the other in front. The tapered edge of both need to point away from the belt to prevent damage. If this is the case, when you disassemble the timing components you will notice a removal of the zinc plating on the washers.
A lot of people screw this up.
Old 08-19-2015, 10:00 PM
lit549's Avatar
There was only one tapered washer ( guide plate) and i installed it correctly..
Old 08-21-2015, 06:55 AM
beocop's Avatar
It could just be a "bad" belt. It could also be from a "wobbly" pulley. Over time, the belt edge gets worn down from an imperfect pulley movement.
Old 08-22-2015, 07:35 AM
lit549's Avatar
How worried should I be? It only has 3000 mi on this belt..All pullies and water pump..I sure hate to tear it down again ,install new belt,and it does the same thing. I even replaced tensioner when I was in there.
Old 08-22-2015, 07:37 AM
lit549's Avatar
I love it when people hijack my thread,lol..
Old 08-24-2015, 03:02 AM
beocop's Avatar
If you don't want to take it apart again just keep paying attention to the noise. If it gets different or louder, it's probably need replacement. For me, I didn't want to hear the noise and since I opened it up already, I just replaced it. At that time, I had driven ~5k miles after the noise started.
Old 08-25-2015, 02:09 PM
lit549's Avatar
Upload some pics,maybe someone will notice something im miss8ng??
Old 08-25-2015, 02:12 PM
lit549's Avatar
Old 08-25-2015, 02:21 PM
lit549's Avatar
See how closest edge has worn?only place it rubs is the water pump pully..Could that be my hummimg noise?I cant find ANYTHING wrong..
Old 08-26-2015, 01:29 PM
beocop's Avatar
Since you already opened it up, just take off the belt and inspect it carefully. It's hard to tell from the pics. I didn't catch the rubbing the first time I opened it. My suggestion is to take the belt off and replace it with a new one so you can eliminate the TB as a cause. After you take off the belt, inspect the other components (pulleys, tensioner, guide plate etc.). If the noise is still there after you put it back, then it's something else.
hondacrx2
Honda Civic (2001 - 2005)
04-04-2017 09:39 PM
pityocamptes
04-22-2011 12:40 PM
dobsogj
05-21-2008 11:14 AM
Metal Head
28
06-12-2007 08:26 PM
importfanatic17
12-03-2006 04:39 PM
Quick Reply: Humming noise
